Results 1 to 2 of 2
Thread: Interference Check
    June 10, 2015
    91
    07:59 PM
    Interference Check
    Hi All,
    How do you run an interference check solely on one floor in a 7 floor project?
    Cheers
    Andy
    May 4, 2011
    111
    02:59 PM
    Using the built-in tool or something better like Navisworks Manage or B360 Glue?
    If the built-in tool in Revit, you don't get much in the way of filtering down what the collision tests are on besides the Family Category. If you've got access to Navis or Glue, you could probably do it either thru a combination of selections/selection sets or by exporting out NWC's of Scope boxes from your Revit model (take a 3D view, orient to your 7th floor floor plan and then adjust the top bottom-if necessary-to floor slab edges. If you don't have access to NavMan, you could probably use Tekla's BIMSight for free.
  1. Interference Check Help
    By waikikigirl in forum MEP - General
    Last Post: October 16th, 2015, 06:22 AM
  2. Interference check
    By fifthtexas in forum MEP - General
    Last Post: August 28th, 2015, 03:38 PM
  3. Replies: 0
    Last Post: January 7th, 2014, 11:45 PM
  4. Revit OpEd: Detail Level and Interference Check
    Last Post: November 13th, 2013, 08:15 PM
  5. Replies: 0
    Last Post: December 5th, 2011, 04:17 AM
