Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Sloping parapet?
    August 9, 2011
    63
    05:22 AM
    Sloping parapet?
    Hey all,
    Is there a way to make a parapet slope with the roof other than cutting the wall profile?
    TIA
    John
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,230
    07:22 AM
    Yep, edit the wall profile. Go to an elevation view, select the wall, then edit profile (up in the ribbon). You will see some pink sketch lines for the wall outline. You can resketch it to whatever you want. If you draw a closed loop with in the main boundry, it will be a hole.
    There's an easier way. Just select the wall and attach it to the roof. It will take on the roof slope as long as they intersect. If not, use the above method.
    I've been working in Autocrap all day on an old project, so my mind isn't in Revit mode. I hate Acad
    August 9, 2011
    63
    05:22 AM
    Quote Originally Posted by dzatto View Post
    Thanks. Is there a way to make the slope "smart" to match the roof slope (in case the slope changes?) like an attach with offset or something?
    dzatto's Avatar
    December 9, 2010
    5,230
    07:22 AM
    Yep, see my post above. I edited it while you were sending your response.
    Moderator mark b's Avatar
    NSW Australia
    1,429
    11:22 PM
    Smart to roof pitch, no don't think so. But edit profile of wall and attach to locked Ref planes (locked to top of roof) will give you smart with height and width changes.
    I assume by parapet you mean your wall finishes above the roofline ?
    Attached Thumbnails Attached Thumbnails Sloping parapet?-1.jpg   Sloping parapet?-2.jpg   Sloping parapet?-3.jpg
    NSW Australia
    1,429
    11:22 PM
    OK just tried adding a dimension (locked) while in edit wall profile locking pink line to roof (not using any ref planes) and works fine when changing Roof Pitch.
    So now the answer is Yes there is a smart way !!
    dzatto's Avatar
    December 9, 2010
    5,230
    07:22 AM
    POTM nominated, sir.
    August 9, 2011
    63
    05:22 AM
    Quote Originally Posted by mark b View Post
    Awesome.. thanks!
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    12:22 PM
    Second that! And added some REP!
    oh crap. No rep since I nominated you first... But I'm thinking REP!REP!REP! so maybe someone else comes along and fixes it.
    dzatto's Avatar
    December 9, 2010
    5,230
    07:22 AM
    Yeah, he has too much rep already. I'm still hanging on significant.
  1. Custom Ramp Rail (Concrete Parapet & Beam)
    By Alfredo Medina in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2015, 08:08 AM
  2. coverage acroterion - parapet
    By pcamliti in forum Architecture and General Revit Questions
    Last Post: November 26th, 2014, 02:05 PM
  3. Curved wall with sloping top
    By Alfienoakes in forum Architecture and General Revit Questions
    Last Post: September 6th, 2014, 07:31 AM
  4. Sloping Chimney Cap
    By dzatto in forum Architecture - Family Creation
    Last Post: July 28th, 2011, 01:01 AM
  5. Sloping pad issue - 2 pads intersecting each other
    By jh75 in forum Structure - General Questions
    Last Post: May 11th, 2011, 02:30 AM
