Results 1 to 2 of 2
Thread: Finding elements find/replace tool
    September 21, 2016
    Boston
    189
    01:22 AM
    I am working on tagging interior windows/glazing using window ghosts and numbering them in sequence. for example, I am naming them W1, W2 and so on as I go through the plan. I ran into the issue where there is a duplicate ghost with the same name, lets say W3 exists somewhere else already and I want to find that one and change it because it's no longer correct. I want to find where that duplicate one is locate it so I can resolve the issue. only, I can't find it anywhere in the plan and want to avoid having to manually scan the floor plan. Is there a way that I could do some kind of find command where it will highlight it if I do some kind of search for it?
    July 4, 2013
    179
    10:22 PM
    Learn your way around schedules. Filter by Type mark equals W3 and it will show all of them in the model.
  1. Replies: 7
    Last Post: June 24th, 2016, 05:38 PM
  2. Trying to find a functioning truss tool/extension.
    By Iron GhostSword in forum Structure - General Questions
    Last Post: December 22nd, 2014, 02:46 PM
  3. Replies: 0
    Last Post: September 6th, 2012, 11:17 PM
  4. Find and replace
    By andyhoman1 in forum Architecture and General Revit Questions
    Last Post: May 9th, 2012, 06:04 PM
  5. Autodesk Find and Replace
    Last Post: July 12th, 2011, 03:45 PM
