Results 1 to 5 of 5
Thread: Divided Surface
    Member feio's Avatar
    December 13, 2010
    Decadent Lisbon
    450
    02:48 PM
    Divided Surface
    I am doing my first curtain panels by pattern, and I am having some problems.
    I need to use the Triangle flat pattern, but I am getting odd results: the orientation is fliiped in a chekered (triangles ) way.
    Half of the panels are oriented to the outside and the other half to the inside.
    Is this normal, and is there a workaround?
    Thanks in advance
    Kingdom of Denmark
    4,223
    03:48 PM
    Hi Gonçalo. Did you get this sorted? If not, could you provide a screenshot to help clarifying the problem?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    01:48 PM
    Or better yet, post the project... It's kind of difficult this way to suggest a solution.
    BUT: you might want to look into the border conditions of your Surface. There are a few settings there and I think you might have it set to "full panels" (or whatever they call it).
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    01:48 PM
    EDIT: sorry, double posting. Got a Database Error and then it all got kind of screwy...
    Kingdom of Denmark
    4,223
    03:48 PM
    Quote Originally Posted by mdradvies View Post
    That would be my fault
  1. Surface Pattern for Topography
    By JCM in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2012, 03:10 AM
  2. Divided parts
    By bjarke78 in forum Architecture and General Revit Questions
    Last Post: July 26th, 2011, 05:30 PM
  3. Problem with Topo surface
    By Ekkan in forum Architecture and General Revit Questions
    Last Post: June 2nd, 2011, 12:26 PM
  4. Room is divided, any way to merge?
    Last Post: May 29th, 2011, 12:08 AM
  5. Surface or Volume
    By Henry in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: April 20th, 2011, 11:33 AM
