Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
Like Tree2Likes
Thread: How do I extract a .PAT file from revit ?
  1. #21
    Gold Coast
    2,641
    10:21 AM
    There is a little trick I discovered on how to get pat files from Revit (in case you were not the originator of the pattern file)...
    Select multiple views for DWG export that has the pattern you want to get... Don't just select one! The pat files will disappear too fast!
    Open one explore window with where your exporting the DWG....open another one to save the PAT files....
    What will happen is you will see the DWG being saved, then PAT files, and when the PCP file is saved the PAT files disappear. I copy and paste all the PAT files into my other open window.
    Now, open the CAD file you just exported and find the fill your wanting to acquire. The pattern name is FP_(x)...you will find that same pattern name in the PAT files you copied over...
    Voila! You have the pattern that you don't have to spend forever trying to recreate...
    EDIT: The reason for the multiple files....when you try to copy and paste Windows will lose the info on what is getting copied...but the next view is the same pat files, so you have time to paste.
    great tip! maybe post it in the tips/tricks forum? *rep
  2. #22
    Member Parametric Snowman's Avatar
    April 27, 2011
    Dallas, Texas
    269
    07:21 PM
    gregory,
    I am still having issue when it comes to creating running bond pattern.
    I followed Thread #8 From Mark but still didn't quite figure it out why it isn't working...
    Attached Thumbnails Attached Thumbnails How do I extract a .PAT file from revit ?-running-bond_fail.jpg
  3. #23
    Moderator mark b's Avatar
    NSW Australia
    1,430
    10:21 AM
    Quote Originally Posted by Parametric Snowman View Post
    gregory,
    Make sure you use the correct Hatch22 line styles from drafting line styles selection. Looking at you screen capture you are using the continuious line style for your brick pattern, use the DASHED line for this as it is actually a dshed pattern. Make sure the colors match mine and it should work.
    Attached Thumbnails Attached Thumbnails How do I extract a .PAT file from revit ?-lines.jpg   How do I extract a .PAT file from revit ?-running.jpg
  4. #24
    January 7, 2011
    39
    06:21 PM
    I agree with Mark B.
  5. #25
    April 27, 2011
    Dallas, Texas
    269
    07:21 PM
    Thanks Mark,
    I tried it last night and I got it to work by switching it to dashed line. but my other question is what if I am want the runnind bond pattern to be continuous line? Do I still use dashed line or continuous line now?
  6. #26
    NSW Australia
    1,430
    10:21 AM
    If you mean you don"t want to see the motar joint, then still use dashed line, but the ends, top and bottom need to be "on" the boundry line. So the first brick (vertical dash line) will be 1 brick + 1 joint long and 1 brick + 1 joint high. The second coarse 1brick + 1 joint high.
    The first brick "length" and second brick "height" form the "boundry line"
  7. #27
    January 7, 2011
    39
    06:21 PM
    Actually (if i understand his no-mortar joint question correctly), then the horizontal lines could/should be continuous since that's how they will actually appear.
    In autocad it would matter. If you'd create a long (continuous) horizontal hatch line with a bunch of short lines, then the drawn hatch wouldn't be as efficient....which would theoretically slow down screen drawing.
    Because I can't 'explode' a hatch in Revit, I don't know if it optimizes itself or not.
    But...to be safe...and clean...I'd make the horizontal lines continuous.
  8. #28
    NSW Australia
    1,430
    10:21 AM
    Quote Originally Posted by mertens3d View Post
    Thanks Gregory, I stand corrected. It does work as dashed, but you are correct "be safe".
  9. #29
    April 27, 2011
    Dallas, Texas
    269
    07:21 PM
    Gregory,
    Got it working now!!!! Thanks for your comments! FYI, the hoz line really need to be continuous...
  10. #30
    September 30, 2011
    2
    08:21 PM
    Great Tip
    I absolutely love it.
  1. Insert a Linked Revit File
    Last Post: May 1st, 2011, 07:08 PM
  2. Revit Journal File Creation
    By msbeham in forum Architecture and General Revit Questions
    Last Post: April 1st, 2011, 08:35 PM
  3. Revit.pat and pattern standards
    Last Post: March 14th, 2011, 07:42 PM
  4. Insert linked revit file
    By redmonki in forum Architecture and General Revit Questions
    Last Post: January 7th, 2011, 02:30 PM
  5. Multi Revit File Project
    By Chowdur in forum Architecture and General Revit Questions
    Last Post: December 15th, 2010, 04:13 PM
