Results 1 to 5 of 5
Thread: Hosted fixtures in curved or sloped ceilings
    November 23, 2012
    82
    03:21 PM
    I'm trying to set some lights into some curved and sloped ceilings. Our lights are all face-based, and they do join with and cut the ceilings.
    But they are perpendicular to the face of the ceiling and real lights, as we all know, are typically installed parallel to the ground, not the ceiling.
    So I'm doing all kinds of hackish things to set them parallel to the floor plane. Is there are any clean way to do this?
    December 21, 2010
    Phoenix, AZ
    2,576
    03:21 PM
    I use a series of nested families with angle parameters to get the nested GA parallel to the floor. The model sits correctly on the slope but shows the symbology in plan.
    Sent from my iPad using Tapatalk
    November 23, 2012
    82
    03:21 PM
    [QUOTE=GMcDowellJr;167038]I use a series of nested families with angle parameters to get the nested GA parallel to the floor. The model sits correctly on the slope but shows the symbology in plan.
    Sadly, I was hoping for something easier - But I was afraid that your solution would be the solution. As a favor, would you mind posting one of your hosted angle-ized fixtures, so I could play with it and see how it's done? I have always had trouble trying to make Revit rotate things in families...
    Thanks.
    December 21, 2010
    Phoenix, AZ
    2,576
    03:21 PM
    Take a look at my post history. I'm pretty sure it's already on the forum. If not, and I remember cone Monday, I'll post another example. It's not so bad to get this into existing families once you get a workflow you like.
    January 18, 2014
    122
    05:21 PM
    This might be what you're looking for:
    https://www.youtube.com/watch?v=6n1PgOAFwwo
  1. Attach a curved wall to a sloped curved floor. HELP!!!!
    By peclat in forum Architecture and General Revit Questions
    Last Post: February 24th, 2017, 08:19 AM
  2. Replies: 2
    Last Post: April 4th, 2014, 01:48 PM
  3. Setting Pendant Lengths of Fixtures on Sloped Surfaces using Dynamo
    By GMcDowellJr in forum Architecture and General Revit Questions
  4. Replies: 0
    Last Post: August 27th, 2013, 03:15 PM
  5. Sloped Ceilings
    By Nivek in forum Architecture and General Revit Questions
    Last Post: October 5th, 2011, 09:10 PM
