Results 1 to 3 of 3
Thread: "Can't make sweep"
    cnd
    cnd is offline
    June 18, 2015
    75
    06:52 PM
    "Can't make sweep"
    For some reason the attached profile can't make a sweep in my project. Any ideas on why? I'm trying to make a generic model in-place family with this profile in the sweep and keep getting an error message.
    Attached Files Attached Files
    July 10, 2015
    Boise, Idaho
    660
    04:52 PM
    I wouldn't be surprised if it's the ellipse section causing the trouble.
    I'd make a test profile that has it as a straight line to see if that's the problem. From there more examination can happen.
    cnd
    cnd is offline
    June 18, 2015
    75
    06:52 PM
    Thanks, it was actually a duplicate line I failed to notice connected to that!
  1. "Can't keep elements joined" error during sweep void cut
    By gpktm in forum Architecture and General Revit Questions
    Last Post: July 25th, 2016, 11:36 AM
  2. Can't make type "Elbow - Soldered - CU : Standard".
    By nick_h in forum MEP - General
    Last Post: July 5th, 2016, 02:17 PM
  3. "3D-profile" sweep/reveal
    By Rvto in forum Architecture and General Revit Questions
    Last Post: February 12th, 2016, 10:35 AM
  4. How do I make "Floor with Flat Top and Sloped Bottom"
    By viratmanchanda in forum Architecture and General Revit Questions
    Last Post: May 5th, 2015, 09:17 AM
  5. In Revit Architecture 2014, dont have "make adaptive" tool.
    By giovanni. in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 25th, 2014, 03:35 AM
