Results 1 to 2 of 2
Thread: What criteria will be used to establish priorities and make design decisions?
    May 23, 2016
    1
    08:48 PM
    How generally architect can make design decision and the priorities
    Senior Member
    December 16, 2010
    856
    06:48 AM
    Bottom line - the client decides.
    Architects will decide based on clients wishes and specifications, and in many cases is limited by government standards.
    (for example the heights of his guard rails are governed by standards)
    Or the maximum height of his building will be limited by state laws.
    If they have free reign on certain elements, then they do the design and pass it on to the client who then approves (or not) and once that process is done, passes it to the engineer who TRIES to make it work, but if the design is flawed or requires additional elements, or is overdesigned, the engineer will often rationalise the design depending on the skill and knowledge of the architect, and also the requirements in the contract.
  1. Autodesk University: Design & Make Contest Update
    By Autodesk University in forum Blog Feeds
    Last Post: November 18th, 2013, 05:15 PM
  2. Replies: 0
    Last Post: October 24th, 2013, 11:15 AM
  3. Revit OpEd: Filter Criteria Order Matters
    Last Post: September 13th, 2013, 03:15 PM
  4. Revit OpEd: OmniClass as Criteria
    Last Post: December 2nd, 2012, 01:15 PM
  5. Building Coder: Sweep PickPath Tolerance Criteria
    Last Post: October 16th, 2012, 12:15 PM
Tags for this Thread
