Results 1 to 5 of 5
Thread: sloped wall joined to sloped roof
    May 11, 2012
    32
    07:46 AM
    Ok, so here is my conceptual mass that I used to generate the walls (by face) and roof (which is actually a wall)
    Works fine for the most part with wall by face, and i've sorted out the joints for the most part, but here revit does somthing weird, how do I make the roof's end flush with the wall?
    And that diagonal line looks hideous, I can't seem to alter the wall joints here, any tips? should I construct this a different way?
    May 11, 2012
    32
    07:46 AM
    Oh, and here is a section of the roof
    Gold Coast
    2,626
    05:46 PM
    Quote Originally Posted by sohn View Post
Name:	Screen Shot 2016-05-13 at 17.47.03.png
Name:	Screen Shot 2016-05-13 at 17.47.22.png
    Im only on my phone so the images are a bit hard to see. Im guessing "And that diagonal line looks hideous.." you mean the mitred condition between roof and wall? Seeing as you used walls for thw roof can you join geometry to hide the join? If you want a separate butt joint (beam on post) look maybe create the roof from a new mass surface which encompasses the full extenet. Or just use a system roof family outside the massing family.
    May 11, 2012
    32
    07:46 AM
    Yes, it's the mitred join, i can't seem to grab the joint with the wall joins tool (works only in plan view?), joining does not help either. I remade the wall and roof using the in-place component tool, that way I could make a clean joint, however the walls are dumb now, no layers within the wall. And mostly irritating is that I can't re-align the pattern (panels) without moving the whole object, as if the pattern i stuck!
    Not sure how to apply your suggestions? I tried the roof tool, same thing there, the ends are squared, and not in flush with the wall angle.
    Gold Coast
    2,626
    05:46 PM
    Yes the wall joins tool will only work in plan.
    If you go back into edit mode the surface pattern lines should move on their own.
    I realise now you want the whole piece of geometry to be clean single item. The only other thing i can think of right now while having a few saturday night brewskies would be to make the whole thing as roof by extrusion where you can actually use layers and keep it (relatively) parametric
    https://knowledge.autodesk.com/suppo...F9953-htm.html
  1. Flat Pad on Sloped Roof
    By B Arch in forum Architecture and General Revit Questions
    Last Post: November 23rd, 2015, 09:36 PM
  2. sloped roof modeling
    By mona miller in forum Architecture and General Revit Questions
    Last Post: May 18th, 2014, 01:15 AM
  3. Sloped glazing in sloped wall
    Last Post: September 7th, 2012, 08:12 PM
  4. Sloped roof
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: March 13th, 2012, 04:40 PM
  5. handrail on sloped roof
    By Povilas in forum Architecture and General Revit Questions
    Last Post: February 27th, 2012, 08:05 AM
Tags for this Thread
