Results 1 to 4 of 4
Thread: Export Element dimensions to schedule/excel?
    May 5, 2016
    2
    11:51 AM
    Question Export Element dimensions to schedule/excel?
    Hi everyone, I'm pretty new to Revit.
    I have created a parametric cabinet that contains about 10 parts/elements (sides, back, doors etc).
    Is there anyway to export the dimensions of those parts to a schedule? I have tried this many times but Revit only seems to count the cabinet as a whole unit rather than breaking it down and providing information on all of its parts/elements.
    Can anyone provide a solution on this?
    Thanks.
    Member jsnyder's Avatar
    December 9, 2010
    AUGI Refugee
    347
    06:51 PM
    Look into shared parameters in your family/project. Shared parameters can appear in tags and schedules.
    Member Exar Kun's Avatar
    August 2, 2011
    208
    11:51 AM
    Look into shared, nested families. Essentially you'd create a basic rectangular prism family (and any other shapes) that you load into the cabinet family and construct it out of those. If they are instance parameters then you can associate them to various parameters in the cabinet family and if the nested family is shared then you can schedule each one in the project.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    09:51 PM
    Quote Originally Posted by Exar Kun View Post
    Shared & Nested families is the way to go. The biggest advantages are it allows you to use a Type parameter and swap parts on the fly rather than having to edit the family and if you update the nested family it will update every instance in the project.
  1. Anyone know how to export Revision Schedules to Excel?
    By viratmanchanda in forum Architecture and General Revit Questions
    Last Post: October 23rd, 2018, 03:14 PM
  2. Excel Export/Import
    Last Post: December 29th, 2015, 02:23 AM
  3. Schedule export to Excel with exact total calculation
    By amkh in forum Architecture and General Revit Questions
    Last Post: January 17th, 2015, 09:24 AM
  4. how to export the schedule in excel format
    By amarkrish108 in forum Architecture and General Revit Questions
    Last Post: April 19th, 2013, 06:15 PM
  5. How can i export quantities schedule to Excel?
    By Nsync in forum Structure - General Questions
    Last Post: December 4th, 2012, 09:53 PM
