Results 1 to 9 of 9
Thread: Sections Referencing Another View Not Visible
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,060
    04:14 PM
    I'm stumped. I'm trying to place a section and have it reference another view but if I select reference other view the section marker is not visible. If I place a normal section everything shows up correctly. I've gone through the Can't See It in the View post and either everything is correct per that post or I'm missing something stupid.
    Both views are in the same phase & design option.
    I've tried Visible at Scales Coarser Than with no luck.
    Everything looks OK in the VT, including filters.
    Nothing shows up if I turn on Hidden Elements
    2016-04-08_1631 - cellophane's library
    Coeur d Alene, ID
    4,640
    01:14 PM
    Think I saw this over at the Autodesk Forums too... What kind of plan is it? Version of Revit?
    August 9, 2011
    Louisville, KY
    6,060
    04:14 PM
    2015
    It is an elevation of a window and I need to reference the typical head detail.
    I saw a post at the Autodesk Forums but the issue they had was related to a filter & changing the view type.
    edit:
    Or I'm a moron and you can't reference a view with section that is of a different type... /sigh Is it Friday yet?
    October 23, 2013
    10
    08:14 PM
    I was having this issue in Revit 2017.2. The solution for me was to turn off the annotation crop on the view I was trying to place the reference section into. Hope this is helpful to others!
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    515
    08:14 PM
    Nothing to do with the section mark "do not show if scale less than" set in the plan view, etc. ?
    Senior Member Alex Page's Avatar
    Wellington, New Zealand
    630
    09:14 AM
    The section you're referencing is'nt on a different phase?
    October 23, 2013
    10
    08:14 PM
    Quote Originally Posted by kamranmirza View Post
    Not for me. Not sure about the Original Poster.
    October 23, 2013
    10
    08:14 PM
    Quote Originally Posted by Alex Page View Post
  9.    #9
    March 12, 2019
    1
    01:14 PM
    I couldn't figure it out either so I ended up using an Elevation Tag and referincing the Section Detail and then drawing a line off the Elevation Tag.
  1. Find Referencing Sections in Project
    By Nakmonadon in forum Architecture and General Revit Questions
    Last Post: October 15th, 2015, 05:38 PM
  2. Finding my details and sections when referencing them.......
    By ecraider in forum Architecture and General Revit Questions
    Last Post: May 7th, 2015, 01:11 AM
  3. Referencing a Drafting View
    By jason.karam in forum Architecture and General Revit Questions
    Last Post: August 14th, 2014, 05:01 AM
  4. Wall Section Referencing Other View
    Last Post: October 18th, 2011, 08:09 PM
  5. Drafting View Sections VS Building Sections
    Last Post: February 21st, 2011, 04:57 PM
