Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree1Likes
Thread: Dimensioning Gridlines
    August 3, 2015
    115
    05:33 PM
    I need to dimension between gridlines, outside the viewort on the sheets. ALL THE SHEETS.
    My 1st thought is to do one edge and mirror. I hope there's something more efficient than this method.
    November 11, 2013
    213
    07:33 PM
    I like to set up a "Grid Layout" view, do all my dimensions there, then just copy and paste it onto every relevant view.
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    551
    01:33 AM
    Just got an idea - we use a linked file called MLG - Master Levels and Grids, then we copy/monitor those grids into our project files. We use it to share with consultants too. That way our grids are controlled and it's very difficult to unintentionally alter the grids and levels.
    I was just thinking, if we had a view in the MLG file that had the grids dimensioned on it, we could just use that as a linked view and set up view templates for the plans accordingly. That way we wouldn't have to copy paste dimensions, all the views would have the same dimensions and we wouldn't have to suffer from any unintentional changes made to dimensions, etc.
    Hmmm. Kamran
    TRWhitehead likes this.
    November 11, 2013
    213
    07:33 PM
    Quote Originally Posted by kamranmirza View Post
    Hmmm. Kamran
    Grids are an annotation item, which don't show in linked models - only model elements do. So, you'd have to find away to show dimensions as a model element, likely a new family type...
    Member TRWhitehead's Avatar
    February 16, 2012
    Portland, OR
    328
    05:33 PM
    This is not true. If you set your view in the MLG file up properly, then set the VG to be "By Linked View" in host model, it will work fine.
    Grids will definitely show up from a linked file and can be dimensioned. I've done it for years. For general annotations you're partially right. But if you use "by linked view" you can get everything that is from the linked file on that view.
    January 12, 2011
    London, UK
    551
    01:33 AM
    Hey thetragicjoy, I may be wrong, but I think you're wrong - grids and levels show very clearly from linked models and we have to keep filtering them out of consultants' models.
    And linked views definitely show up annotations like spot levels and dimensions.
    Kamran
    February 16, 2012
    Portland, OR
    328
    05:33 PM
    ...if we had a view in the MLG file that had the grids dimensioned on it, we could just use that as a linked view and set up view templates for the plans accordingly. That way we wouldn't have to copy paste dimensions, all the views would have the same dimensions and we wouldn't have to suffer from any unintentional changes made to dimensions, etc.
    That's a pretty good idea. I'm going to try that soon.
    January 12, 2011
    London, UK
    551
    01:33 AM
    Snap to Tom - he was faster on the draw !
    10,341
    07:33 PM
    TTJ is wrong: Annotations CAN show up from linked models. Grids show up automatically by default, because of the nature of *grids,* other annotations (aside from levels) dont show up unless you set the linked model to BLV.
    Something to think about, is youre going to get in to the "loop paradox" if you try to put the MLG model on BMV to show the grids and the dimensions: Then youre going to have to ONLY show the Linked Grids, and not your own, or youll have duplicates. Its also annoying as all get out, to not be able to adjust grid heads in your own file. But, if you hide the grids in the MLG file, the dimensions will vanish.
    Personally? I think you should dimension them on the plans that need them (in your main file), and leave it as that. Of course, i dont believe in dimensioning them on every plan either. That belief isnt software driven, either. I think its a generally bad practice.
    November 11, 2013
    213
    07:33 PM
    Hey, it's good to be wrong sometimes. I was referring to dimensions not showing, not the grids.
  1. Overlapping Gridlines
    By mdomer in forum Architecture and General Revit Questions
    Last Post: March 14th, 2016, 05:02 PM
  2. Monitor linked gridlines.
    By domsib in forum Architecture and General Revit Questions
    Last Post: August 20th, 2012, 03:03 PM
  3. In trouble with GridLines disappearing
    By Yan Naing Bo in forum Structure - General Questions
    Last Post: October 17th, 2011, 04:22 AM
  4. gridlines
    By elton williams in forum Architecture and General Revit Questions
    Last Post: October 13th, 2011, 06:58 PM
  5. Visible gridlines in assembly
    By Odemeer in forum Architecture and General Revit Questions
    Last Post: July 19th, 2011, 12:48 PM
