Results 1 to 4 of 4
Thread: Offset of curtain wall panel form basic wall
    Member byk3bep's Avatar
    January 30, 2014
    450
    03:34 AM
    Is it possible and how to set the offset of a curtain wall made form basic wall?
    When I change it to a panel in the panel properties the offset parameter is available, but as soon as I switch it to a basic wall, it "jumps" so the location line is the center line.
    February 2, 2011
    Montreal/Paris
    830
    08:34 PM
    Curtain Wall don't have an offset value. They are define by the location at placement. So you can take the entire wall and move it.
    December 20, 2010
    1,071
    09:34 PM
    I believe you can tab select the wall and chose its location line and "location line offset". You have to select the wall panels themselves,its not in the curtain wall propertiesOffset of curtain wall panel form basic wall-cw.jpg
    January 30, 2014
    450
    03:34 AM
    Hey, thx, that looks good.
    I have to select the panels I want to offset. Could be an issue down the line.
  1. Curtain Wall Offset Mullions Both Continuous
    By veuxx in forum Architecture and General Revit Questions
    Last Post: August 7th, 2014, 05:00 PM
  2. Curtain wall offset
    By byk3bep in forum Architecture and General Revit Questions
    Last Post: July 21st, 2014, 07:10 AM
  3. Curtain Wall with base offset of 2' - help please.
    By digitalputty in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2012, 08:42 PM
  4. Sticky Notes: Curtain Wall Basics - Empty Curtain Panel
    By Sticky Notes in forum Blog Feeds
    Last Post: June 14th, 2012, 02:45 PM
  5. Offset Curtain Wall Panel
    By DaveP in forum Tutorials, Tips & Tricks
    Last Post: June 8th, 2012, 08:15 PM
