Results 1 to 6 of 6
Thread: Diffuser family does not actually attach to the Ceiling Grid?
    September 17, 2013
    Detroit
    35
    04:26 PM
    Why is this? Lights attach and move to the ceiling grid, but diffusers dont?
    January 17, 2011
    2,044
    11:26 AM
    See if it's a ceiling hosted Family.
    September 17, 2013
    Detroit
    35
    04:26 PM
    Its the Revit OOTB family... I checked the family and its hosted on a generic extrusion, and don't think its ceiling hosted, is there a way to change that within the family?
    January 17, 2011
    2,044
    11:26 AM
    Try these from the OOTB library:
    These both should mount directly to ceilings.
    September 17, 2013
    Detroit
    35
    04:26 PM
    Thanks! Its hosted to the ceiling... however it does not move with the ACT grid when its readjusts ?
    Mr. Revit OpEd
    2,907
    09:26 AM
    Only a ceiling based family will follow the grid when it is moved and only when both the family and the ceiling are in the same model. A face-based family is only recognizing the face of the ceiling not the grid. There is no easy way (like a check box to tick) to make a face-based family a ceiling based family...other than remaking it.
    I get around the grid movement issue by selecting the families that should move with the grid at the same time with the grid/ceiling. Pretty easy.
  1. Radial ceiling grid
    By DaveP in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2014, 01:47 PM
  2. Ceiling Grid
    By domsib in forum MEP - General
    Last Post: April 30th, 2013, 04:25 PM
  3. Loading of Diffuser family
    By zacoolm in forum MEP - General
    Last Post: April 22nd, 2013, 07:54 PM
  4. Placing Air Terminal (Diffuser) inside a 2x2 ceiling grid
    By lukewallace1990 in forum MEP - General
    Last Post: November 25th, 2012, 05:11 PM
  5. Attach to Grid Option?
    Last Post: September 20th, 2012, 07:37 PM
