Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree2Likes
Thread: Can this be done? (L-shaped retaining wall with sloping base/Tilted L-shaped wall)
    December 7, 2015
    12
    11:27 PM
    For a landscape project, we have an abundance of L-shaped retaining walls (several hundred meters). Terrain is also sloping, and the top of the retaining walls needs to approximately follow the terrain. I want to do something like the attached screenshots (from a Sketchup-model). That is, either the entire length of wall is rotated, so that it's perpendicular to the ground slope, OR, it's just that one end is lifted. Both will do, but the former is better.
    I'm using stacked walls to get L-shape retaining walls that also shows up in schedules, so I can't edit the wall profile, it will cut off the "foot" of the L-element (see attached pic). I thought I could use a wall sweep (I've haven't used those before), but can't quite figure out how to use it with a 3d base line. Also not sure how "schedulable" that would be, or how I would edit it? I know this project will go through plenty of terrain changes, so ideally, any solution would not mean having to manually edit a mass each time.
    Can it be done?
    Attached Thumbnails Attached Thumbnails Can this be done? (L-shaped retaining wall with sloping base/Tilted L-shaped wall)-stacked_wall_editprofile.png   Can this be done? (L-shaped retaining wall with sloping base/Tilted L-shaped wall)-retaining_walls2.png   Can this be done? (L-shaped retaining wall with sloping base/Tilted L-shaped wall)-retaining_walls1.png
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    401
    04:27 PM
    Component: Model-in-Place.. and select Walls for your category?
    Member Barth's Avatar
    December 2, 2013
    300
    03:27 PM
    Just thinking outside the box here, Glenn...looks like a something that could be accomplished with Ramps and Rails. Might be worth a consideration. Good luck.
    December 7, 2015
    12
    11:27 PM
    Quote Originally Posted by ryntau View Post
    Well, yeah, that's what I'm trying to avoid, the mass modelling, since I would like something that's a little more convenient when changing the heights.
    December 7, 2015
    12
    11:27 PM
    Quote Originally Posted by Barth View Post
    That's not a bad idea at all! I can't recall right now (not at my work computer), but is the base of the ramp horizontal in plan or does it follow the top profile of the ramp? Otherwise, that might be just the ticket. Well, except for the scheduling part, but that's not the most important.
    Gold Coast
    2,609
    09:27 AM
    Have a look at Make Hardscape Follow Site Topography and Site Topography Follow Hardscape in Revit if you need perfection, but real world...we usually just stick to edit profile on a wall which gives good enough for estimates/quotes anyway. Real world retaining walls will never be exact no matter how good your drawings are.
    Mr. Revit OpEd
    2,866
    04:27 PM
    Flat floors for the "L" then use shape editing to move the slab ends down/up. Sketch a wall over the floor and attach the base to the floor. If the top needs to be parallel to slope, edit the profile of the wall afterward. All pretty simple tasks without requiring any real cleverness.
    December 2, 2013
    300
    03:27 PM
    Drew likes this.
    December 2, 2013
    300
    03:27 PM
    Elton: Great Contribution! Thanks for sharing the link! Make Hardscape Follow Site Topography and Site Topography Follow Hardscape in Revit
    Drew likes this.
    May 30, 2015
    200
    06:27 PM
    How about a couple simple adaptive component families
  1. Wedge shaped foundation wall
    By cw202t in forum Architecture and General Revit Questions
    Last Post: November 5th, 2014, 07:37 PM
  2. Aligning a V groove shaped reveal
    By Joshua Kohl in forum Architecture - Family Creation
    Last Post: April 17th, 2014, 08:34 PM
  3. Tube shaped Space Elevation
    By leetecture in forum Architecture and General Revit Questions
    Last Post: December 10th, 2013, 01:11 PM
  4. Help with Barrel Shaped Roof with Angled Walls
    By melloblkmon in forum Architecture and General Revit Questions
    Last Post: November 15th, 2013, 02:12 PM
  5. Oddly shaped duct - thoughts?
    By Andrew K in forum MEP - Family Creation
    Last Post: March 25th, 2013, 01:07 PM
