Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree2Likes
Thread: Multiple sessions of revit open causes the little wheel to spin spin spin
    December 20, 2010
    1,036
    04:44 PM
    Does anyone know why if I have one session of Revit 2015 open and one session of 2016 open that it would cause one to slow down(little green i'm thinking circle) between every command?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,060
    04:44 PM
    I have the same issue. I've been chalking it up to needing more RAM but it is possible there is some conflict as well.
    Win 8.1 Pro x64
    i7-4790 3.60GHz
    16Gb
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,479
    01:44 PM
    Quote Originally Posted by sdbrownaia View Post
    I've never experienced this sort of thing and work on projects in R2012, 2014, 2015, and 2016 concurrently all of the time. Perhaps as Cellophane mentions, a RAM issue?
    July 10, 2015
    Boise, Idaho
    611
    02:44 PM
    16GB RAM should be enough today. Tomorrow will need 32 and next week you'll need 64.
    Member Markus's Avatar
    July 27, 2012
    Seattle, WA, United States of America
    332
    12:44 PM
    We encountered this issue, but it was not tied to opening different versions of Revit on the same workstation. We got the spinning doughnut syndrome when there was a second person in the model.
    1) Use Windows Task Manager to identify whether it is the CPU or RAM is peaking during the spinning moment.
    2) Use Wireshark or MS Process Manager (Revit.exe) to see where Revit is stalling.
    3) Were there any major updates in your network infrastructure: new file servers, converted servers to a new OS, new router, etc.
    Item 3 was the cause of our grief - it turned out to be an arcane error of a processing bottleneck at the NIC interface when we upgraded file servers. I think it was tied to SMB2 vs. SMB3
    Autodesk has also resported the symptom can relate to using different OS for different workstations on the same project (related to SMB versions).
    btw. I tested on our system - no problems working in Revit 2015-UR9 and 2016-UR2 concurrently on the same workstation.
    December 20, 2010
    1,036
    04:44 PM
    I have 32gb of ram so I think its not that.
  7.    #7
    February 10, 2011
    35
    03:44 PM
    Scott, Did you ever figure this out? I have had the same issue for a while now. Two sessions of Revit 2018.3 open and the cursor constantly spins... but only when the cursor is within one of the Revit apps. I don't see any CPU or RAM spikes. I have a very capable computer (i9 and 32GB Ram and the faster SSDs). No fun!
  8.    #8
    February 10, 2011
    35
    03:44 PM
    Funny… I think I just figured it out. I got to thinking, Scott probably has similar things installed (i.e. Revit add-ins). I just killed the ‘ArchVision Dashboard’ process and it immediately stopped.
    Dave Jones likes this.
  9.    #9
    Austin, Texas
    286
    03:44 PM
    Quote Originally Posted by UpNorth View Post
    Thank you! I've had this problem for quite some time over multiple machines. Killing ArchVision Dashboard process eliminated it
  10.    #10
    December 20, 2010
    1,036
    04:44 PM
    yep worked!!!
    Twiceroadsfool likes this.
  1. Replies: 0
    Last Post: October 9th, 2015, 02:15 AM
  2. Autodesk University: Take the wheel
    By Autodesk University in forum Blog Feeds
    Last Post: July 22nd, 2015, 04:45 PM
  3. Replies: 0
    Last Post: September 23rd, 2013, 05:45 AM
  4. Revit OpEd: Options Bar and the Mouse Wheel Zooming
    Last Post: May 13th, 2013, 03:15 PM
  5. Navigation Bar and/or Steering Wheel
    By DaveP in forum Architecture and General Revit Questions
    Last Post: July 20th, 2012, 07:44 PM
