Results 1 to 4 of 4
Thread: Linked CAD not visible in other floors of project
    June 23, 2011
    2
    05:29 AM
    Hello Forum,
    I am new to revit and just finished some ATC classes. I am stumped and need guidance. I linked in a dwg floor plan and it shows on the first floor but not in the 2nd floor or any others views. I thought as long as you left "current view only" in the Link CAD Dialog box unchecked it should show in all views. Thank you in advance for any replies
    Ny Mech
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    09:29 AM
    Well, it could also be by default hidden in the other views. Also, your View Range needs to be set to a correct height. Post the project, we might have a look...
    This thread could also be helpful (all known ways why something won't show up in a view. Must have for starters!!)
    August 31, 2011
    pretoria
    1
    11:29 AM
    hi guys,
    i have been having a similar problem. i link a dwg in to revit and it only shows up in the 3D view. and not on any of the floor plans. would any one have an idea on how to sort this out please.
    tumo
    St. Louis, MO
    1,954
    04:29 AM
    Go to a section or elevation view. In VG make sure Imported Categories is turned on. Then turn all other categories off--this will expose the cad dwg.
    It will show up as a thing horizontal colored line, because you are looking at it straight on and it's flat.
    You may need to copy it up to the 2nd Level.
    cheers
  1. Filled Regions and Floors
    By retroface in forum Architecture and General Revit Questions
    Last Post: June 17th, 2011, 01:49 PM
  2. Context Masses Visible Good, Concept Masses Visible Bad
    Last Post: June 14th, 2011, 05:11 AM
  3. Looking for the post regarding cad files moving when project is reopened
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: April 13th, 2011, 03:30 PM
  4. Creating Basement Floors
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 09:04 AM
  5. Lock a Linked Project?
    Last Post: March 14th, 2011, 03:07 PM
Tags for this Thread
