Results 1 to 6 of 6
Thread: Convert Project Parameter to Shared Parameter
    Junior Member Rustle's Avatar
    Portland, OR
    22
    12:40 PM
    I know with the Extensions you can convert familiy parameters to shared parameters but I would like to do this with project parameters. Does anyone know if that is possible at this time?
    Rustle
    United States
    1,144
    01:40 PM
    I was looking for this same thing the other day and was to no avail. I do not believe this is possible at this time.
    Nantes, France
    1,380
    08:40 PM
    Hi guys,
    there's a way to achieve this. first you should have already a shared parameter file related to your project.
    Go to Manage>project parameters. Select the parameter and then Modify.
    Select in the window Export. get an info message then OK.
    Go to shared parameters, you have now a new group named Exported parameters.
    Select the parameter you've just exported, then Move.
    Select now the group of the other shared parameters. You're done.
    Your exported parameter is available in other projects as a shared one.
    Let me know if you have problems.
    See below please......
    United States
    1,144
    01:40 PM
    Quote Originally Posted by jbenoit44 View Post
    When I go to do this "Export" is grayed out so I cannot select to export...am I missing something?
    Nantes, France
    1,380
    08:40 PM
    Checking.............................
    So, my fault my very fault, what I explained was in fact a way to keep already SHARED parameter when the .txt file is missing.( I did it a little too fast......it's bed time for me now!)
    Sorry guys, no way to transfer Project parameter to Shared one.(for now, I will test something at work tomorrow).
    But there always a way to transfer Project parameter to another one with Transfer Project Standards
    see you
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    07:40 PM
    As far as I know, it can't be done...
  1. Shared Parameter Category
    Last Post: May 24th, 2011, 11:39 AM
  2. Area Type parameter
    By gaby424 in forum Architecture - Family Creation
    Last Post: May 8th, 2011, 12:46 PM
  3. Filter by Shared Parameter?
    Last Post: March 28th, 2011, 05:02 PM
  4. Project Parameter for Solar Orientation & Stacked Walls don't mix?
    Last Post: February 23rd, 2011, 04:53 PM
  5. Another Parameter Topic
    By Alex Cunningham in forum Architecture - Family Creation
    Last Post: January 30th, 2011, 12:28 AM
