Results 1 to 9 of 9
Like Tree5Likes
  • 1 Post By Robin Deurloo
  • 2 Post By rkitect
  • 1 Post By rkitect
  • 1 Post By rkitect
Thread: Insert a door in curtain wall
    August 18, 2015
    63
    07:01 PM
    Hello,
    I really need an urgent help.
    I am a beginner and got stuck 3 days in insert a door in curtain wall and also a stair from level zero to one.
    Could some one contact me to help as I have to deliver it
    July 7, 2011
    Rotterdam, Holland
    1,252
    09:01 PM
    You can exchange a glass panel in a curtail wall for a door. Select the glass (use the TAB key to select it easily).
    It is most likely locked, so unlock the panel and change it to a door by choosing the right door in your properties panel. You do need to have the right door in your project of course.
    Attached is a door we use in our curtain walls you can use to reverse engineer if needed.
    Attached Files Attached Files
    cganiere likes this.
    July 7, 2011
    Rotterdam, Holland
    1,252
    09:01 PM
    Placing a stairs should be easy, just choose the 2 levels it needs to connect in the properties panel before placing it (can do that after too, but I think it is better before).
    Senior Member rkitect's Avatar
    April 21, 2011
    Oklahoma
    773
    02:01 PM
    If you have about 20-30 minutes, there is a brief curtain wall primer available here:
    Part 1: Revit TotD ? 6.5.09: Curtain Wall Series.1 | Navigating the waters.
    Part 2: Revit Totd ? 6.8.09: Curtain Walls.2 | ?WHY CAN?T I MOVE GRIDS!??!??
    Part 3: Revit TotD ? 6.9.09: Curtain Walls.3 | The Curtain Panel
    Part 4: Revit TotD ? 6.10.09: Curtain Walls.4 | Curtain Wall Doors <<< this is the one about doors!
    Part 5: Revit TotD ? 6.11.09: Curtain Walls.5 | Advanced Curtain Wall Types
    Unfortunately they have not been updated from when they were done in the pre-ribbon universe, but the same methods still apply :] Hope this helps!
    cganiere and travis86 like this.
    August 18, 2015
    63
    07:01 PM
    Thank you all,
    first problem after i deleted the bottom mulin from the door I can not choose the panel , I tap on it I tried a lot but I can not
    with the stair I could not make it connected to the roof I mean to make an opening from the end of the stair and the roof :
    July 7, 2011
    Rotterdam, Holland
    1,252
    09:01 PM
    You should be able to pick the panel by clicking on the sides of it, try one of the otters if the bottom is hidden or does not work, using TAB if needed. Clicking in the middle of the panel will not work usually.
    Either create a level for the top of your stairs or give the stairs a manual height. Stairs will not create the opening in the roof or floor, you will have to do that manually.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,510
    12:01 PM
    Quote Originally Posted by Somaya View Post
    Thank you all,
    tabbing to find a curtain panel is sometimes a chore especially if your curtain wall mullion profiles have glazing pockets designed in them. When that happens I just crossing window select and filter the panel, like this
    April 21, 2011
    Oklahoma
    773
    02:01 PM
    Thank you all,
    If you are using 2015 or later, you should also be sure that you have the Pinned Objects selection filter turned off so that you can select panels. If they are tabbed and this selection filter is turned on you will not be able to select it (but you probably wouldn't have been able to select the mullion either so I'm not sure this is the issue)
    Robin Deurloo likes this.
    April 21, 2011
    Oklahoma
    773
    02:01 PM
    I should clarify: If the Mullion type, Panel type or grid dimensions are defined in the Curtain Wall type, then when you create an instance of that wall type all of these objects will be locked by default. If you have the pinned object selection filter activated, then you will not be able to select those objects until after you unpin them or disable the selection filter.
  1. Curtain Wall - finish wrapping @ insert?
    Last Post: April 20th, 2016, 09:31 PM
  2. Curtain wall door
    By constrainmenot in forum Architecture and General Revit Questions
    Last Post: December 17th, 2014, 06:59 PM
  3. Replies: 0
    Last Post: May 31st, 2013, 11:15 PM
  4. Replies: 0
    Last Post: May 24th, 2013, 12:15 AM
