Results 1 to 7 of 7
Thread: "Can't keep elements joined" error during sweep void cut
    Member gpktm's Avatar
    October 22, 2012
    Melbourne, Australia
    144
    07:16 AM
    Question "Can't keep elements joined" error during sweep void cut
    Hi everyone
    I need some help to create a fillet edge by using a sweep void cut but I'm getting can't keep elements joined error which I cannot understand where is referring to. Can someone solve it for me please? And explain me what's wrong. The file is in Revit 2014 format.
    PS: Anyone knows if Autodesk is planning to add a fillet tool someday in the future? There are unlimited times when it can be useful.
    Attached Thumbnails Attached Thumbnails "Can't keep elements joined" error during sweep void cut-sweep-path.jpg   "Can't keep elements joined" error during sweep void cut-error.jpg
    Attached Files Attached Files
    March 14, 2012
    Luleå, Sweden
    11
    09:16 PM
    I usually get that error when the void sweep ends on the edge of the solid. You might try to extend the path line past the solid.
    As to the fillet, there is such a tool already:
    October 22, 2012
    144
    07:16 AM
    - I did extend the path, check the attached RFA file.
    - No that's not fillet tool for surfaces and solids, that is for lines.
    March 14, 2012
    Luleå, Sweden
    11
    09:16 PM
    Quote Originally Posted by gpktm View Post
    Yes. You didn't really specify you were looking for a fillet tools for surfaces and solids though.
    October 22, 2012
    144
    07:16 AM
    I guess was pretty obvious mate. That's what I was trying to achieve in that Revit family.
    September 16, 2015
    Darwin, Australia
    171
    06:46 AM
    I agree, a 3D fillet tool would be great.
    In regards to your question however, I find that Revit has trouble cutting long sweeps in one pass. Perhaps you could try and and create multiple void forms (one for each curve in the profile) instead. That's worked for me in the past.
    *EDIT* Also try to ensure that the edges of your profile are not flush with the solid geometry, let it hang over the edge of that cushion. I just had a play with your family and it seems to work after doing what I just wrote. Good luck, I hope I was of some help.
    July 11, 2016
    10
    09:16 PM
    Did you ever find the solution? I've run into the same problem and its driving me mad
  1. Error Question Two elements were not automatically joined because one or both is not
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: December 23rd, 2014, 02:28 PM
  2. "Can't keep wall and roof joined": why so vague?
    By lost again again in forum Architecture and General Revit Questions
    Last Post: March 24th, 2014, 04:44 PM
  3. Error Message when trying to Adjust Exposure in "Render in Cloud"
    By efficiencydesign in forum Architecture and General Revit Questions
    Last Post: March 10th, 2014, 06:21 PM
  4. Error Message: "None of the created elements are visible in Floor Plan"
    Last Post: March 8th, 2014, 07:05 AM
  5. Can't cut object - "Can't keep elements joined" error
    By gpktm in forum Architecture - Family Creation
    Last Post: March 6th, 2014, 01:19 PM
Tags for this Thread
