Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Visible gridlines in assembly
    June 28, 2011
    3
    06:11 AM
    Is it possible to add gridlines to an assembly (i believe not) or is there a way to make them visible in the assembly-views if there not part of the assembly?
    Thnx
    United States
    1,141
    11:11 PM
    From my experience (which granted is limited) with the assemblies is that assembly views only show what is in the assembly and nothing else. So if your grids are part of the assembly (which is not a good idea) they will show up...otherwise they will not.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    05:11 AM
    Without any experience in Assemblies: that sucks... Especially in Assemblies you might want to know where they are located. The whole point is the possibility to take a part of the building and easily make separate (construction) drawings isn't it? But you can't show where it's taken? That kind of defeats the purpose doesn't it?
    Nantes, France
    1,380
    06:11 AM
    you can show where the assembly is by adding an assembly tag. you may also add a reference to the sheet with assemblies views. like a callout.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    05:11 AM
    Ok, but in Holland we have the customary approach to annotate from the gridlines... that isn't going to be possible with an Assembly View?
    United States
    1,141
    11:11 PM
    Quote Originally Posted by mdradvies View Post
    You are not able to show grids that are not part of the assembly in and assembly view.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    05:11 AM
    Quote Originally Posted by gdoherty0102 View Post
    But as you stated earlier: incorporating them isn't a good idea... So too bad, not much use for it here.
    Autodesk Scott D Davis's Avatar
    March 5, 2011
    Southern California
    653
    10:11 PM
    Annotations cannot be part of the objects selected to create an assembly. This includes levels and grids. You can annotate an assembly after it's created, but then you cannot create grids in an assembly view.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    05:11 AM
    Quote Originally Posted by Scott D Davis View Post
    Why not? Renders it useless for me... We measure distances from Grids if possible. Will this be included in next versions?
    March 5, 2011
    Southern California
    653
    10:11 PM
    Not sure why it was done this way, and i don't want to speculate. Not sure what will be in 2013, and couldn't tell you here in a public forum if I knew :-)
  1. Assembly Codes/Uniformat
    By Aretap in forum Architecture and General Revit Questions
    Last Post: September 12th, 2018, 11:42 AM
  2. gridlines
    By elton williams in forum Architecture and General Revit Questions
    Last Post: October 13th, 2011, 06:58 PM
  3. Context Masses Visible Good, Concept Masses Visible Bad
    Last Post: June 14th, 2011, 05:11 AM
  4. Cutout visible in 3D view?
    By stl4310 in forum Rendering and Gallery
    Last Post: February 15th, 2011, 09:02 AM
  5. Assembly Codes
    By violet78 in forum Architecture - Family Creation
    Last Post: January 12th, 2011, 01:43 AM
Tags for this Thread
