Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree9Likes
Thread: Dimensioning curved geometry
    cnd
    cnd is offline
    June 18, 2015
    75
    04:39 AM
    I am looking to be able to dimension the distance between several offset curves for a curved piece of cabinetry. As far as I can tell there is no good way to do this, unless I'm missing something. Anyone know of a way to do this, or even a workaround to 'fake' it?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,556
    03:39 AM
    Something like this would be my best guess:
    http://www.revitforum.org/architectu...tml#post131349
    cnd
    cnd is offline
    June 18, 2015
    75
    04:39 AM
    Unfortunately I don't think that has much to do with my issue. I have in plan a curve, which is a portion of a circle and then repeating offset circular curves. My goal is to be able to annotate these curves, showing the offset dimension between, as that is the dimension I want to hold. Short of drawing a perpendicular line between each curve and dimensioning that, I'm not sure how to accomplish this.
    I thought of providing a series of radial dimensions, but that is leaving too much to the end user to figure out the difference between each.
    May 18, 2011
    Calgary, AB
    227
    01:39 AM
    I'm working on a "curved" building.
    Short answer, no. Revit doesn't dimension between two parallel or (non parallel for that matter) curves.
    You could draw a line perpendicular to the curves and dimension the intersections - which doesn't work for non parallel curves. You can't delete the line or the dimensions go with it, so it might have to be turned white.
    We're using Point Layout and giving northings and eastings for the contractor to build from. Alternative to point layout would be spot coordinates along the curve at a set distance (1m or something to that extent).
    December 13, 2010
    Whangarei, New Zealand
    144
    09:39 PM
    Instead of drawing a line, place a reference plane, which don't show when printed (if set in the print setup.)
    Attached Thumbnails Attached Thumbnails Dimensioning curved geometry-dimensioning_offset_circles.png
    8,481
    02:39 AM
    If you dimension to an object that doesnt show when printed, im pretty sure the dimension wont show up either...
    Mr. Revit OpEd
    2,392
    12:39 AM
    Quote Originally Posted by Twiceroadsfool
    If you dimension to an object that doesn't show when printed, I'm pretty sure the dimension wont show up either...
    ...unless the things that don't print are reference planes...and in this case the reference planes allow the dims to exist but it looks like they are referencing the intersecting arcs.
    cganiere likes this.
    8,481
    02:39 AM
    Woah, really!? Thats freaky! I didnt think you could do that, even with Ref Planes! Learned something new today!
    Tim West likes this.
    Mr. Revit OpEd
    2,392
    12:39 AM
    Just don't turn off Reference Planes in V/G that will kill the dims too.
    cganiere and Ning Zhou like this.
    8,481
    02:39 AM
    Ahhhhh. That makes more sense. Mine are all off in VG AND the Print Dialogue. So the print Dialogue wont kill the dims. Thats great to know! Awesome tip.
  1. Curved window on curved wall how ?
    By ahmed_hassan in forum Architecture - Family Creation
    Last Post: April 11th, 2017, 07:28 PM
  2. Please Help! Model Surface Patterns on Curved wall profiles and curved wall segments
    By nealasullivan in forum Architecture and General Revit Questions
    Last Post: April 28th, 2015, 03:59 PM
  3. How to make curved windows on curved walls?
    By jessema in forum Architecture and General Revit Questions
    Last Post: October 26th, 2014, 09:58 AM
  4. Curved wall not attaching to curved roof...
    By roseman5285 in forum Architecture and General Revit Questions
    Last Post: June 1st, 2013, 08:40 AM
  5. Dimensioning
    By Ashwini in forum Architecture and General Revit Questions
    Last Post: March 19th, 2013, 01:27 PM
