Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Model pattern not visible on ramps in plan views?
    Member need4mospd's Avatar
    March 2, 2011
    Houston
    480
    10:22 AM
    Have I lost it, or is this really happening? Open a blank file, draw a ramp and assign any MODEL pattern to the material. View the ramp in plan and 3D view. The pattern is visible in 3D views and elevations, but not plan.
    Why is this, and what have you done to "fix" it?
    I was originally using sloped floors but railing doesn't play nice with those.
    Clay
    Rotterdam, South Holland
    3,065
    05:22 PM
    Nope, you haven't lost it. Stairs work the same way. You will see those model patterns in 3D, and even in elevation. But in plan stairs, ramps and rails all show a bit of a fabricated 2D representation, which ignores model patterns. Probably a genius idea in 1999 when processors where about as fast as a three toed sloth, but long sense more like a bug than a feature. I suspect the fix will be a byproduct of these items eventually getting a ground up rewrite, rather than just the pattern problem getting fixed.
    Gordon
    St. Louis, MO
    1,954
    10:22 AM
    It might be possible to use a Plan Region around the ramp, set the cut plane to slice thru and show the cut pattern?
    Member krispy5's Avatar
    December 21, 2010
    68
    02:22 AM
    No, since ramps are not cut by the cut plane
    March 2, 2011
    Houston
    480
    10:22 AM
    Yeah, couldn't get anything to work that great. Just resorted to doing model lines on the surface. Works ok, just a little more work involved.
    March 2, 2011
    Houston
    480
    10:22 AM
    Scratch that previous post. Model lines do not work OK on ramps...see attached image...
    Attached Thumbnails Attached Thumbnails Model pattern not visible on ramps in plan views?-ramp-model-lines.png
    St. Louis, MO
    1,954
    10:22 AM
    Another way might be to use a Floor with a Slope Arrow or edited points instead of a Ramp.
    March 2, 2011
    Houston
    480
    10:22 AM
    Cliff, I tried railing on sloped floors first and it required even more workarounds. If you have a ramp with a mid landing, the balusters just follow the first section of ramp and burry themselves in the rest of the ramp. I tried doing multiple rails just sectioned on each piece of ramp and it was a pain to get everything lined up. Railing works MUCH better on ramps, and if I can have railing that works easy, I'd rather just find a work around for the ramp surface. Maybe I'll just do sweep reveals...
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    10:22 AM
    You can do it with a filter. Just create a filter called Ramps (or whetever). It will be associated with ramps (obviously). Leave the filter rules as none.
    Add it to your view, then override the surface pattern. I did the same thing to show a surface pattern on a wall that's below the cut plane.
    Nevermind. I missed the part about the MODEL patterns. Oops.
    Attached Thumbnails Attached Thumbnails Model pattern not visible on ramps in plan views?-capture.jpg
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    03:22 PM
    Can you paint the surface??
  1. How is Generic Model Pattern Based different from Curtain Panel Pattern Based
    By shtirlits in forum Architecture - Family Creation
    Last Post: October 5th, 2012, 12:14 AM
  2. Piping not visible in two views (3D vs Plan)
    By tzframpton in forum MEP - General
    Last Post: October 15th, 2011, 05:22 AM
  3. Stacking views on sheets to negate single cut pattern per element
    By ekkonap in forum Architecture and General Revit Questions
    Last Post: June 16th, 2011, 11:09 AM
  4. Column visibility in plan view (totally same columns, different views)
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: May 27th, 2011, 08:34 AM
  5. Copy and paste between plan and elevation Views
    By willsud in forum Architecture and General Revit Questions
    Last Post: March 30th, 2011, 09:31 PM
