Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Twiceroadsfool
Thread: Creating Ceilings from Massing?
    December 1, 2011
    Hong Kong
    39
    02:52 PM
    Here's a question that I can't seem to find an answer to. How can one create ceilings for a multi-story (62 floors) tower where every floor and ceiling will be different. Somehow one should be able to do it the same way as creating floors from the massing.
    Here is a link to a Revit file that will demonstrate what I need.
    Revit Model
    Currently, I'm simply using a floor family, but then I cannot seem to edit the grid, add lights, etc.
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    327
    06:52 AM
    there's no "create ceiling from Face" option in revit. Conceptual Mass is for conceptual studies, area schemes etc, not for detailed building models.
    you could make walls by face, an then ceiling by "pick walls"..
    10,127
    01:52 AM
    It's not accurate to say that ceilings don't ever take shapes of things that are double curved or irregular, which requires massing. For that, we use Roofs. Since all of our fixtures are face based, it works fine.
    IzabelAlvarenga likes this.
    December 1, 2011
    Hong Kong
    39
    02:52 PM
    Yes, but how could one create it off your massing form, like with massing floors? Building 62 individual ceiling is simply not convenient, lol.
    Surely, this is not the first Revit model of a high rise tower with varying shaped floors/ceilings.
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    787
    01:52 AM
    How about automatic ceiling tool in the project? It's not 'ceiling by mass', but it can greatly speed up the process of ceilings creation.
    December 6, 2018
    1
    01:52 AM
    Roof as ceiling
    Are your light fixtures face based? Does matter the type of construction? (roof, ceiling, wall) How do I do that?
    10,127
    01:52 AM
    Mine are either Face Based (does not matter what type of item the Face is created from) or Unhosted. I use very little Ceiling Hosted content.
    January 19, 2012
    325
    01:52 AM
    FYI, you can convert your System Host Based families into Face Based Families by using the "pyRevit" App with its tool called "Convert Family to Face Host Based". If you built those families with the Extrusions locked to Reference Planes that are then locked to the System Host then it's an easier transition by simply deleting the System Host that would then be converted to an Extrusion by the tool to complete the process. Otherwise the Face it uses to Reference will be rotated in the original Y-axis. If you have nested Host based families within the Family then they too will be converted.
    I've just converted a few nested Plumbing families I had that were Wall Host based to Face Based just recently to success.
  1. Vaulted Ceilings
    By CADLee in forum Architecture and General Revit Questions
    Last Post: May 13th, 2017, 07:18 AM
  2. Replies: 3
    Last Post: January 28th, 2015, 06:40 PM
  3. Ceilings
    By KK1975 in forum Architecture and General Revit Questions
    Last Post: October 15th, 2014, 09:19 PM
  4. Vaulted Ceilings
    By Dieseltwitch in forum Architecture and General Revit Questions
    Last Post: February 15th, 2013, 01:16 PM
  5. Sloped Ceilings
    By Nivek in forum Architecture and General Revit Questions
    Last Post: October 5th, 2011, 09:10 PM
