Page 1 of 12 1234511 ... LastLast
Results 1 to 10 of 114
Like Tree45Likes
Thread: Revit 2016 .ini file
    Member BD Mackey's Avatar
    November 1, 2013
    466
    12:05 AM
    So I have installed Revit 2016 and I was looking at customizing the .ini file for consultants and have found Japanese and Chinese language in it. It seems default installation has directory locations for different languages, are others seeing the same thing.
    DirectoriesCHS]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2016\Family Templates\Chinese\
    DataLibraryLocations=Library=C:\ProgramData\Autode sk\RVT 2016\Libraries\Generic\
    DefaultTemplate=构造样板=C:\ProgramData\Autodesk\RVT 2016\Templates\Generic\Default_M_CHS.rte, 建筑样板=C:\ProgramData\Autodesk\RVT 2016\Templates\Generic\Default_M_CHS.rte, 结构样板=C:\ProgramData\Autodesk\RVT 2016\Templates\Generic\Default_M_CHS.rte, 机械样板=C:\ProgramData\Autodesk\RVT 2016\Templates\Generic\Default_M_CHS.rte
    [DirectoriesCHT]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2016\Family Templates\Traditional Chinese\
    DefaultTemplate=建構樣板=C:\ProgramData\Autodesk\RVT 2016\Templates\Generic\Default_M_CHT.rte, 建築樣板=C:\ProgramData\Autodesk\RVT 2016\Templates\Generic\Default_M_CHT.rte, 結構樣板=C:\ProgramData\Autodesk\RVT 2016\Templates\Generic\Default_M_CHT.rte, 機械樣板=C:\ProgramData\Autodesk\RVT 2016\Templates\Generic\Default_M_CHT.rte
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    401
    12:05 AM
    Brian, do you have a process that you go through to create your custom .ini file? I think my current office has just been upgrading their template, so it hasn't been done in a while, so I'd like to dig into it this year.
    Mr. Revit OpEd
    2,830
    12:05 AM
    This release provides all language support with one installation and switching language support without a separate language pack installation. It means that localized versions will be available when the English language version ships.
    November 1, 2013
    466
    12:05 AM
    Ryan, Yes I always customize the .ini file for my clients when I create deployments. Over the years I have been getting them from different user machines from different disciplines so I can see what can go into one, especially since the help file only covers the basics.
    Steve, Thanks I didn't know this was a feature of 2016, guess I can just remove that from my .ini file since I will only be using English.
    9,906
    02:05 AM
    Here is mine, so far, for 2016. There are a few new options that showed up in 2015, R2, and 2016. Im liking a lot of the new user configurability. This means we can push more settings we like, on Rollout.
    [Revit.ini]
    [Colors]
    HiliteColor=3618815
    PreHiliteColor=16733610
    ErrorColor=33023
    CustomColor1=b7ad94
    CustomColor2=97b2a1
    CustomColor3=f1e1d4
    CustomColor4=e2cdff
    CustomColor5=d2c6bd
    CustomColor6=66c0e6
    CustomColor7=97e3ff
    CustomColor8=8ea5ee
    CustomColor9=a16fa1
    CustomColor10=887888
    CustomColor11=dea9ae
    CustomColor12=b0daf5
    CustomColor13=909495
    CustomColor14=77daff
    CustomColor15=f2a75e
    CustomColor16=85afbf
    BackgroundColor=16777215
    [Directories]
    ProjectPath=C:\Temp
    ImportLineweightsNameDWG=\\dalfs\Revit\2016\Beck Project Template\ImportLayers-NCS40.txt
    IESFileLocation=\\dalfs\Revit\Beck IES Files
    LookupTableLocation=\\dalfs\Revit\2016\Beck Support Files\Support-MEP-LookupTables
    MaterialLibraryFiles=\\dalfs\Revit\Beck Material Maps
    RootPathForPointClouds=C:\Scans
    AdditionalRenderAppearancePaths=\\dalfs\Revit\Beck Material Maps\Ceilings\|\\dalfs\Revit\Beck Material Maps\Concrete\|\\dalfs\Revit\Beck Material Maps\Masonry-Block\|\\dalfs\Revit\Beck Material Maps\Masonry-Brick\|\\dalfs\Revit\Beck Material Maps\Masonry-Stone\|\\dalfs\Revit\Beck Material Maps\Metals\|\\dalfs\Revit\Beck Material Maps\Misc\|\\dalfs\Revit\Beck Material Maps\Paints and Papers\|\\dalfs\Revit\Beck Material Maps\Site\|\\dalfs\Revit\Beck Material Maps\Tile\|\\dalfs\Revit\Beck Material Maps\Woods\
    ExternalParameters=\\dalfs\Revit\2016\Beck Project Template\Beck Shared Parameters.txt
    [UserInterface]
    DoubleClickFamily=NoAction
    DoubleClickSketchedElement=EditType
    DoubleClickViewOnSheet=ActivateView
    DoubleClickAssembly=EnterEditMode
    DoubleClickGroup=EnterEditMode
    DoubleClickComponentStairs=EnterEditMode
    DisplayRecentFilesPage=0
    DisableMppAutoApply=1
    [Language]
    Select=ENU
    [Applications]
    Mechanical=
    Electrical=
    Architectural=
    Structural=
    [InstallationSettings]
    Language=ENU
    Usage=All
    [Install]
    InstallGUID=
    [ContentSearch]
    [Documentation]
    HelpFileLocation=C:\Program Files\Autodesk\Revit Content 2016\Help\en-US\WBH\index.html
    [DirectoriesENU]
    FamilyTemplatePath=\\dalfs\Revit\2016\Beck Family Templates
    DataLibraryLocations=Families=\\dalfs\Revit\2016\B eck Family Content
    DefaultTemplate=Beck Project=\\dalfs\Revit\2016\Beck Project Template\Beck-Template-R2016.rte
    [Misc]
    CEAServerAddress=https://gbs-adn.autodesk.com/gbs/SOAP/ceaservice.svc?WSDL
    SSOServer=0
    [Messages]
    AdlmCheckoutBefore=0
    SuppressForceRasterPrintingWarning=1
    SuppressShowMassWarning=0
    SuppressShowButtonMessage=1
    [Selection]
    AllowLinkSelection=1
    AllowUnderlaySelection=0
    AllowPinnedSelection=1
    AllowFaceSelection=1
    AllowPressAndDrag=0
    [Partitions]
    WorksharingDisplayFrequency=5
    Username=
    [Graphics]
    OptimizedViewNavigation=1
    Antialiasing=1
    SemiTransparent=1
    ShowMaterialEditor=1
    AntialiasingOptions=0
    ThinLinesEnabled=0
    [AppFrame]
    Theme=1
    [Windows]
    Maximized=1
    [Spelling]
    OptionFlagsSSCE=18
    [Backups]
    SaveReminderMinutes=15
    SaveToCentralReminderMinutes=15
    [ViewOptions]
    DefaultViewDiscipline=Architecture
    [ACMSettings]
    ACMOnNetwork=1
    ACMNetworkPort=14931
    [AutoCam]
    SteeringWheelShowHUDMessages=1
    SteeringWheelShowTooltips=1
    SteeringWheelShowToolCursorText=1
    BigSteeringWheelSize=1
    BigSteeringWheelOpacity=1
    MiniSteeringWheelSize=1
    MiniSteeringWheelOpacity=1
    SteeringWheelInvertVerticalAxis=0
    SteeringWheelConstrainWalkAngleToGround=1
    SteeringWheelSpeedFactor=30
    SteeringWheelEnableIncrementalZoomIn=0
    SteeringWheelKeepSceneUpright=1
    ViewCubePosition=0
    ViewCubeOpacity=2
    ViewCubeSize=4
    ViewCubeSnapToClosestView=1
    ViewCubeFitToView=1
    ViewCubeUseAnimatedTransition=1
    ViewCubeKeepSceneUpright=1
    [Macro]
    AppSecurity=0
    UIDocSecurity=0
    [DNSM]
    TaskDialog_Stairs_Convert_To_Custom=8
    [ChainOptions]
    Components=1
    Stairs=1
    [Recent File List]
    [Recent Workset List]
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,055
    03:05 AM
    two quick questions -
    what are all the custom colors for (i haven't installed 2016 yet)
    when setting the 1 / 0 switches:
    1=enabled
    0=disabled
    correct?
    November 1, 2013
    466
    12:05 AM
    Wow Aaron I am surprised you have animated transitions. Custom colors show up when you are selecting colors for materials, line types, etc.. They are usually the white squares on the left.
    Yes 1=enable and 0=disable
    Here was mine for 2015, however I do much more for clients
    [Revit.ini]
    [Colors]
    CustomColor1=000000
    CustomColor2=0000ff
    CustomColor3=00ffff
    CustomColor4=00ff00
    CustomColor5=ffff00
    CustomColor6=ff0000
    CustomColor7=ff00ff
    CustomColor8=ffffff
    CustomColor9=ffffff
    CustomColor10=ffffff
    CustomColor11=ffffff
    CustomColor12=ffffff
    CustomColor13=ffffff
    CustomColor14=ffffff
    CustomColor15=ffffff
    CustomColor16=ffffff
    HiliteColor=16747353
    PreHiliteColor=12401408
    ErrorColor=33023
    [Directories]
    ProjectPath=C:\Revit Local Projects
    ImportLineweightsNameDWG=C:\Program Files\Autodesk\Revit 2015\Data\importlineweights-dwg-default.txt
    MaterialLibraryFiles=..\Data\Rendering
    IESFileLocation=C:\ProgramData\Autodesk\RVT 2015\IES\
    LookupTableLocation=C:\ProgramData\Autodesk\RVT 2015\Lookup Tables\
    ExternalParameters=J:\Standards\11A. Revit\11A.5 KLAA Library\KLAA_SharedParameterFile.txt
    RootPathForPointClouds=C:\Brian\Revit_Projects\Poi ntClouds
    [DirectoriesENU]
    FamilyTemplatePath=..\..\..\ProgramData\Autodesk\R VT 2015\Family Templates\English_I
    DataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RVT 2015\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RVT 2015\Libraries\US Imperial\Detail Items
    DefaultTemplate=Construction Template=..\..\..\ProgramData\Autodesk\RVT 2015\Templates\US Imperial\Construction-Default.rte, Architectural Template=..\..\..\ProgramData\Autodesk\RVT 2015\Templates\US Imperial\default.rte, Structural Template=..\..\..\ProgramData\Autodesk\RVT 2015\Templates\US Imperial\Structural Analysis-Default.rte, Mechanical Template=..\..\..\ProgramData\Autodesk\RVT 2015\Templates\US Imperial\Mechanical-Default.rte
    [UserInterface]
    CategoryDisciplineFilter=31
    DoubleClickSketchedElement=EnterEditMode
    DisplayRecentFilesPage=1
    [Language]
    Select=ENU
    [Applications]
    Mechanical=
    Electrical=
    Architectural=
    Structural=
    Language=ENU
    Usage=All
    [Install]
    InstallGUID={8AADE249-F976-467C-AD4E-D055B23B50CF}
    [ContentSearch]
    Site=http://seek.autodesk.com
    [Documentation]
    UseHelpServer=1
    HelpBrowser=0
    HelpFileLocation=C:\Program Files\Autodesk\Revit Content 2015 English\Help\en-US\WBH\index.html
    [Misc]
    SSOServer=0
    [Windows]
    Maximized=0
    [Graphics]
    ThinLinesEnabled=1
    Antialiasing=1
    AntialiasingOptions=1
    SemiTransparent=1
    UseGraphicsHardware=1
    [Partitions]
    [ChainOptions]
    Sweep Path=0
    Beams=0
    Lines=0
    Walls=1
    Stairs=1
    Components=0
    Rebar Lines=0
    [Selection]
    AllowPressAndDrag=0
    AllowFaceSelection=0
    [AutoCam]
    NavBarActiveWheel=0
    NavBarVisible=1
    ShowViewCube=1
    [Messages]
    SuppressShowButtonMessage=0
    [AppFrame]
    Theme=1
    [Prompts]
    TooltipAssistance=1
    [Export]
    ExportDwfObjectData=1
    ExportDwfRoomData=0
    [TagOnPlacement]
    StructuralBeam=0
    Rotterdam, South Holland
    3,039
    08:05 AM
    Custom colors also show up in the color picker, so you can seed those 16 squares with office vetted colors for lots of uses. I like providing 8 pastel/earthy colors and a matching 8 more vibrant variants, ready for use is all sorts of cases, especially custom room and area stuff. Users can quickly choose a color, and the color is part of a consistent graphic language.
    9,906
    02:05 AM
    Quote Originally Posted by BD Mackey View Post
    I think it helps the staff stay oriented, when they can see things moving. If it snaps and is suddenly *changed* it can be disorienting.
    3,039
    08:05 AM
    It occurs to me that animated transitions might be the best GPU benchmark we have. If your computer can't handle animated transitions, it can't handle the work either.
    N_Hollenbeck likes this.
  1. Revit 2016
    By Dsmelcer in forum Out There
    Last Post: May 27th, 2016, 01:55 AM
  2. Revit MEP 2016 Fabrication Parts
    By Chris.kershaw in forum MEP - General
    Last Post: May 4th, 2015, 06:22 PM
  3. Revit 2016 and .rcp link problem
    By mihan in forum Architecture and General Revit Questions
    Last Post: April 23rd, 2015, 02:45 PM
  4. Replies: 0
    Last Post: March 29th, 2015, 10:45 PM
