Page 12 of 12 FirstFirst ... 289101112
Results 111 to 114 of 114
Like Tree45Likes
Thread: Revit 2016 .ini file
  1.    #111
    December 17, 2012
    Stuttgart
    21
    09:13 AM
    Its Hex Code, but not in RGB order. Instead of 123456, its 563412.
    [...] the numbers are still Hex, just in decimal format. https://www.binaryhexconverter.com/h...imal-converter
    Ha Aaron u geek, thanks I have tested your color values, and copied them I have sorted the ini file a bit, so it's easier to update in the future. One more question: the files for "AdditionalRenderAppearancePaths", what kind of files are these? Image tiles? You got there several libraries with ceiling, concrete etc.
    Atm I have just inserted a place holder. And the IES files, are the OOTB files good enough to use?
    Code:
    [Revit.ini][ACMSettings]
    ACMOnNetwork=1
    ACMNetworkPort=14931
    [AppFrame]
    Theme=1
    RibbonRefreshInterval=500
    [Applications]
    Mechanical=0
    Electrical=0
    Architectural=1
    Structural=0
    [AutoCam]
    BigSteeringWheelSize=1
    BigSteeringWheelOpacity=1
    MiniSteeringWheelSize=1
    MiniSteeringWheelOpacity=1
    NavBarVisible=1
    NavBarActiveZoom=0
    NavBarActiveWheel=6
    NavBarActiveSPaceMouseCommand=2
    SpaceMouseMode=2
    ShowViewCube=1
    SteeringWheelInvertVerticalAxis=0
    SteeringWheelConstrainWalkAngleToGround=1
    SteeringWheelSpeedFactor=30
    SteeringWheelEnableIncrementalZoomIn=0
    SteeringWheelKeepSceneUpright=1
    SteeringWheelShowHUDMessages=1
    SteeringWheelShowTooltips=1
    SteeringWheelShowToolCursorText=1
    ViewCubePosition=0
    ViewCubeOpacity=2
    ViewCubeSize=4
    ViewCubeSnapToClosestView=1
    ViewCubeFitToView=1
    ViewCubeUseAnimatedTransition=0
    ViewCubeKeepSceneUpright=1
    [Backups]
    SaveReminderMinutes=60
    SaveToCentralReminderMinutes=30
    JournalShelfCapacity=20
    JournalShelfLife=20
    [ChainOptions]
    Lines=1
    Beams=1
    Components=1
    Creases=1
    Stairs=1
    Sweep Path=1
    Walls=1
    [Colors]
    BackgroundColor=16777215
    CustomColor1=b7ad94
    CustomColor2=97b2a1
    CustomColor3=f1e1d4
    CustomColor4=e2cdff
    CustomColor5=d2c6bd
    CustomColor6=66c0e6
    CustomColor7=97e3ff
    CustomColor8=8ea5ee
    CustomColor9=a16fa1
    CustomColor10=887888
    CustomColor11=dea9ae
    CustomColor12=b0daf5
    CustomColor13=909495
    CustomColor14=77daff
    CustomColor15=f2a75e
    CustomColor16=85afbf
    HiliteColor=3618815
    ErrorColor=33023
    PreHiliteColor=16733610
    [Directories]
    ProjectPath=%userprofile%\Documents
    ImportLineweightsNameDWG=C:\Program Files\Autodesk\Revit 2019\Data\importlineweights-dwg-default.txt
    MaterialLibraryFiles=..\Data\Rendering
    IESFileLocation=C:\ProgramData\Autodesk\RVT 2019\IES\
    LookupTableLocation=C:\ProgramData\Autodesk\RVT 2019\Lookup Tables\
    RootPathForPointClouds=%userprofile%\Documents\PointClouds
    AdditionalRenderAppearancePaths=\\EnjoyBIM_NAS\Revit\EnjoyBIM Material Maps\Decken\|\\EnjoyBIM_NAS\Revit\EnjoyBIM Material Maps\Beton\
    ExternalParameters=..\..\..\ProgramData\Autodesk\RVT 2019\Templates\Germany\Revit Gemeinsam Genutzte Parameter-DEU.txt
    [DirectoriesDEU]
    FamilyTemplatePath=..\..\..\ProgramData\Autodesk\RVT 2019\Family Templates\German
    DataLibraryLocations=Metric Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\Germany\,Metric Detail Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\Germany\,Areabook Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\Areabook Library,Buildingbook Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\Buildingbook Library,Roombook Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\Roombook Library
    DefaultTemplate=Construction-Vorlage=..\..\..\ProgramData\Autodesk\RVT 2019\Templates\Germany\BIM_Architektur_und_Ingenieurbau.rte, Architektur-Vorlage=..\..\..\ProgramData\Autodesk\RVT 2019\Templates\Germany\BIM_Architektur_und_Ingenieurbau-Vereinfacht.rte
    [DirectoriesCHS]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Chinese\
    DataLibraryLocations=Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\Generic\,Areabook Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\Areabook Library,Buildingbook Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\Buildingbook Library,Roombook Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\Roombook Library
    DefaultTemplate=构造样板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHS.rte, 建筑样板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHS.rte, 结构样板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHS.rte, 机械样板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHS.rte
    [DirectoriesCHT]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Traditional Chinese\
    DefaultTemplate=建構樣板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHT.rte, 建築樣板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHT.rte, 結構樣板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHT.rte, 機械樣板=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CHT.rte
    [DirectoriesCSY]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Czech\
    DefaultTemplate=Stavební šablona=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CSY.rte, Architektonická šablona=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CSY.rte, Konstrukční šablona=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CSY.rte, Mechanická šablona=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_CSY.rte
    [DirectoriesENU]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\English\
    DefaultTemplate=Construction Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENU.rte, Architectural Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENU.rte, Structural Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENU.rte, Mechanical Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENU.rte
    [DirectoriesENG]
    DefaultTemplate=Construction Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENG.rte, Architectural Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENG.rte, Structural Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENG.rte, Mechanical Template=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ENG.rte
    [DirectoriesESP]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Spanish\
    DefaultTemplate=Plantilla de construcción=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ESP.rte, Plantilla arquitectónica=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ESP.rte, Plantilla estructural=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ESP.rte, Plantilla mecánica=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ESP.rte
    [DirectoriesFRA]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\French\
    DefaultTemplate=Gabarit de construction=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_FRA.rte, Gabarit architectural=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_FRA.rte, Gabarit de structure=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_FRA.rte, Gabarit de génie climatique=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_FRA.rte
    [DirectoriesITA]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Italian\
    DefaultTemplate=Modello di costruzione=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ITA.rte, Modello architettonico=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ITA.rte, Modello strutturale=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ITA.rte, Modello meccanico=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_ITA.rte
    [DirectoriesJPN]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Japanese\
    DefaultTemplate=建設テンプレート=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_JPN.rte, 建築テンプレート=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_JPN.rte, 構造テンプレート=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_JPN.rte, 機械テンプレート=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_JPN.rte
    [DirectoriesKOR]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Korean\
    DefaultTemplate=시공 템플릿=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_KOR.rte, 건축 템플릿=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_KOR.rte, 구조 템플릿=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_KOR.rte, 기계 템플릿=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_KOR.rte
    [DirectoriesPLK]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Polish\
    DefaultTemplate=Szablon konstrukcji=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PLK.rte, Szablon architektoniczny=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PLK.rte, Szablon konstrukcyjny=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PLK.rte, Szablon mechaniczny=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PLK.rte
    [DirectoriesPTB]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Portuguese\
    DefaultTemplate=Modelo de construção=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PTB.rte, Modelo de arquitetura=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PTB.rte, Modelo estrutural=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PTB.rte, Modelo mecânico=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_PTB.rte
    [DirectoriesRUS]
    FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\Russian\
    DefaultTemplate=Шаблон строительства=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_RUS.rte, Архитектурный шаблон=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_RUS.rte, Шаблон несущей конструкции=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_RUS.rte, Шаблон механического оборудования=C:\ProgramData\Autodesk\RVT 2019\Templates\Generic\Default_M_RUS.rte
    [Documentation]
    HelpBrowser=0
    OnlineHelpLocale=deu
    [Export]
    ExportACAObjects=1
    ExportDwfObjectData=1
    ExportDwfRoomData=1
    [Graphics]
    TempDimFontSizeInPoints=10
    OptimizedViewNavigation=1
    Antialiasing=1
    AntialiasingOptions=0
    SemiTransparent=1
    ThinLinesEnabled=0
    ShowMaterialEditor=1
    HiddenSlabEdge=None
    TempDimTextBackground=1
    UseGraphicsHardware=1
    [InstallationSettings]
    Language=DEU
    Usage=All
    [Install]
    InstallGUID=
    [Language]
    Select=DEU
    [Macro]
    AppSecurity=0
    UIDocSecurity=0
    [Misc]
    SSOServer=0
    [Partitions]
    WorksharingDisplayFrequency=5
    [SamplesDEU]
    DefaultSamples=Architektur Ingenieurbau=BIM_Projekt_Golden_Nugget-Architektur_und_Ingenieurbau.rvt, Gebäudetechnik=BIM_Projekt_Golden_Nugget-Gebaeudetechnik.rvt
    [Selection]
    AllowLinkSelection=1
    AllowUnderlaySelection=0
    AllowPinnedSelection=1
    AllowFaceSelection=1
    AllowPressAndDrag=0
    [Spelling]
    OptionFlagsSSCE=18
    LanguageCode=9
    ArchDict=
    CustomDict=
    [Snapping]
    EnableAngularIncrementSnaps=1
    AngularSnapIncrements=180.0000°;90.0000°;45.0000°;15.0000°;5.0000°;1.0000°;
    EnableLinearIncrementSnaps=1
    ImperialSnapIncrements=0
    MetricSnapIncrements=1
    SnapToEndPoints=1
    SnapToMiddle=1
    SnapToNearest=1
    SnapToWorkPlaneGrid=0
    SnapToIntersections=1
    SnapToCenters=1
    SnapToPerpendicular=1
    SnapToTangents=1
    SnapToQuadrants=1
    SnapToPoints=1
    SnapToRemoteObjects=1
    SnapToPointClouds=1
    SnapsOff=0
    [Status Bar]
    ShowDesignOptionOnStatusBar=1
    ShowWorksetOnStatusBar=1
    [TagOnPlacement]
    Areas=1
    CableTray=0
    CommunicationDevices=0
    Conduit=0
    DataDevices=0
    Doors=1
    DuctCurves=0
    DuctTerminal=0
    ElectricalEquipment=0
    ElectricalFixtures=0
    FabricReinforcement=0
    FireAlarmDevices=0
    FlexDuctCurves=0
    FlexPipeCurves=0
    LightingDevices=0
    LightingFixtures=0
    MechanicalEquipment=0
    MEPSpaces=0
    NurseCallDevices=0
    PipeCurves=0
    PlaceHolderDucts=0
    PlaceHolderPipes=0
    PlumbingFixtures=0
    Rooms=1
    SecurityDevices=0
    Sprinklers=0
    StructuralBeam=0
    StructuralBeamSystem=0
    StructuralBrace=0
    StructuralColumn=0
    StructuralTruss=0
    TelephoneDevices=0
    Windows=1
    Wire=0
    [UserInterface]
    ActivateContextualTabOnSelection=1
    CategoryDisciplineFilter=31
    DoubleClickFamily=NoAction
    DoubleClickSketchedElement=EditType
    DoubleClickViewOnSheet=ActivateView
    DoubleClickAssembly=EnterEditMode
    DoubleClickGroup=EnterEditMode
    DoubleClickComponentStairs=EnterEditMode
    DisplayRecentFilesPage=0
    DisableMppAutoApply=1
    LockDisciplineOption=1
    StayOnTheModifyTabInFamilyEditor=0
    StayOnTheModifyTabInProjectEnvironment=0
    [ViewOptions]
    DefaultViewDiscipline=Architectural
    [Windows]
    Maximized=1
  2.    #112
    9,675
    02:13 AM
    AdditionalRenderAppearancePaths: These are directory locations. If you have any Images you want to be available as Render Assets, or directories with RPC files, you put those here. It doesnt automatically pick up Subfolders, so i list out the directories that have all my custom Material Render Images in them.
    IES: Is a directory. And i drop the ones from manufacturers in there.
  3.    #113
    Gold Coast
    2,453
    06:13 PM
    HiliteColor, PreHiliteColor, ErrorColor, and BackgrounColor, are NOT hex codes. They are just numbers. I get those numbers by changing them on my machine, and then seeing what number pops up.
    Exactly what I do because...
    Quote Originally Posted by GMcDowellJr View Post
    Took me so long to figure that out.
    ...I never figured it out
  4.    #114
    December 17, 2012
    Stuttgart
    21
    09:13 AM
    that makes sense. I have added some paths for my english speaking folks and for the Revit Certification, which is based the US Metric Content.
    Which ones are the most important for the Revit certification and I should add to the list?
    Code:
    [DirectoriesENU]FamilyTemplatePath=C:\ProgramData\Autodesk\RVT 2019\Family Templates\English\
    DataLibraryLocations=Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Metric\,Areabook Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\Areabook Library,Buildingbook Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\Buildingbook Library,Roombook Library=C:\ProgramData\Autodesk\RVT 2019\Libraries\US Imperial\Roombook Library
    DefaultTemplate=Construction Template Metric=C:\ProgramData\Autodesk\RVT 2019\Templates\US Metric\Construction-DefaultMetric.rte, Default Template Metric=C:\ProgramData\Autodesk\RVT 2019\Templates\US Metric\DefaultMetric.rte, Structural Analysis Metric Template=C:\ProgramData\Autodesk\RVT 2019\Templates\US Metric\Structural Analysis-DefaultMetric.rte, Systems Default Metric Template=C:\ProgramData\Autodesk\RVT 2019\Templates\US Metric\Structural Analysis-DefaultMetric.rte, Mechanical Default Metric Template=C:\ProgramData\Autodesk\RVT 2019\Templates\US Metric\Mechanical-Default_Metric.rte, Electrical Default Metric Template=C:\ProgramData\Autodesk\RVT 2019\Templates\US Metric\Electrical-Default_Metric.rte, Plumbing Default Metric Template=C:\ProgramData\Autodesk\RVT 2019\Templates\US Metric\Plumbing-Default_Metric.rte
    /e2:
    And now I have added the language specific sample files, which I think is not documented:
    Code:
    [SamplesDEU]
    [SamplesENU]
    DefaultSamples=Architecture Advanced Project=rac_advanced_sample_project.rvt, MEP Advanced Project=rme_advanced_sample_project.rvt, Structure Advanced Project=rst_advanced_sample_project.rvt, Technical School=Technical_school-current_m.rvt, Arch Basic Project=rac_basic_sample_project.rvt, MEP Basic Project=rme_basic_sample_project.rvt, Struc Basic Project=rst_basic_sample_project.rvt
    Is there a way to specify the Sample Familes as well?
    /e3:
    Added another section:
    Code:
    [Manage Links]
    RevitLinks=0
    CADFormats=0
    DWFMarkups=0
    RevitLinksSortDirection=0
    CADFormatsSortDirection=0
    DWFMarkupsSortDirection=0
    [Prompts]
    TooltipAssistance=7
    [Spelling]
    OptionFlagsSSCE=18
    LanguageCode=9
    ArchDict=C:\ProgramData\Autodesk\RVT 2019\RevitDEU.dic
    CustomDict=C:\ProgramData\Autodesk\RVT 2019\Custom.dic
    Attached Thumbnails Attached Thumbnails Revit 2016 .ini file-us-metric.png   Revit 2016 .ini file-newproject.jpg   Revit 2016 .ini file-samplesenu.jpg
    Last edited by Thommynat0r; January 11th, 2019 at 10:48 AM. Reason: added section :)
  1. Revit 2016
    By Dsmelcer in forum Out There
    Last Post: May 27th, 2016, 01:55 AM
  2. Revit MEP 2016 Fabrication Parts
    By Chris.kershaw in forum MEP - General
    Last Post: May 4th, 2015, 06:22 PM
  3. Revit 2016 and .rcp link problem
    By mihan in forum Architecture and General Revit Questions
    Last Post: April 23rd, 2015, 02:45 PM
  4. Replies: 0
    Last Post: March 29th, 2015, 10:45 PM
