Results 1 to 3 of 3
Thread: Detail Items Shifting when Crop Region is Adjusted
    August 16, 2013
    Houston, Texas
    2
    02:13 AM
    I am working with a detail group in a detail call-out of a wall section. I have been asked to adjust the crop region of the call-out. However, every time I attempt to adjust the crop region various detail items, mainly filled regions move in some (arbitrary) relationship to the adjustment in the crop boundary. At first I thought that I had accidentally moved the view. I undid the command and tried again with the same result. The movement suggests that the the filled region boundary is somehow locked to the crop region, which I didn't think was possible. The fix is just to edit the group which isn't terribly time consuming, but at this point I just want to know why it's doing this. Or is this just some bug that I should ignore. Using Revit 2013.
    St. Louis, MO
    1,954
    02:13 AM
    Yes--I have noticed this using Revit 2015 as well.
    I tried pinning the detail items, but cannot confirm if this keeps them from moving when the crop boundary is adjusted--will have to test it.
    In the mean time, we have pinned all the section marks so the boundary cannot be adjusted by mistake.
    August 16, 2013
    Houston, Texas
    2
    02:13 AM
    Thanks for the help. I'll try the pinning method for now.
  1. section mark still show up way beyond crop region and annotation crop
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: November 5th, 2017, 05:42 PM
  2. 2014: Is the new Crop Region really just a Masking Region?
    By DaveP in forum Architecture and General Revit Questions
    Last Post: July 31st, 2013, 10:26 PM
  3. Detail Groups Shifting when copied
    By robieszuds in forum Architecture and General Revit Questions
    Last Post: May 23rd, 2013, 07:58 PM
  4. Tagging items in a Plan Region.
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: July 31st, 2012, 07:52 PM
  5. Crop Region rotation?
    Last Post: March 6th, 2012, 08:28 PM
