Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By DesignApparatus
Thread: Visibility issue thru floors
    Member DesignApparatus's Avatar
    July 20, 2011
    San Diego, CA
    183
    06:41 AM
    OK, I think I am not seeing the forest for the trees so to speak. I have a project I am doing an as-built for. It is truly basic...2 stories, so 2 levels.
    I am just doing floor plans for each floor. In level 2 I am still seeing all of the elements in level 1 below...even though I have a floor placed between them. I even have the walls on level 1 going only up to a intermediate level (top of plate), not up to level 2. The walls below do not "attach" to the floor placed on level 2. The view range only references level 2 and does not indicate "level below". I have the view depth set to "Associated Level (Level 2)" and the bottom of the view range is set to Associated Level (Level 2)...so what gives?
    I have never encountered this problem...even re-booted to make sure I was not getting a funky graphics card "ghost" or something.
    Chime in if you have an idea!
    April 4, 2013
    92
    08:41 AM
    Quote Originally Posted by DesignApparatus View Post
    I know this is super obvious, but do you have an underlay on?
    Else post the file or screenshot would be helpful.
    July 20, 2011
    San Diego, CA
    183
    06:41 AM
    Hit me over the head with a forest tree! You know, I have never had that issue in 6 years. I installed my update to RVT2015 and somehow that setting must be on by default or something...it did not even occur to me. I need a drink...leaving work early now
    CHEERS!
    cellophane likes this.
  1. Revit OpEd: Visibility of Floors and their Parts
    Last Post: February 12th, 2015, 03:15 PM
  2. Beginner's Question: Issue With Siding Extended to Cover Floors
    By colokate in forum Architecture and General Revit Questions
    Last Post: February 8th, 2014, 04:52 PM
  3. Room tag visibility issue
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: November 1st, 2013, 11:46 PM
  4. Rediculous Column Visibility Issue
    By Grumple in forum Architecture and General Revit Questions
    Last Post: October 25th, 2013, 02:24 PM
  5. Visibility issue
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: November 29th, 2011, 02:58 PM
