Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree1Likes
Thread: View Reference tag that can display a view's name too not just sheet and number data?
    December 3, 2012
    73
    11:37 AM
    Also tried adding a shared parameter to the View Reference Tag family but I can't.
    Any thoughts?
    Gold Coast
    2,266
    09:37 PM
    Quote Originally Posted by basilmir View Post
    Any thoughts?
    I could be wrong bc I'm not near Revit to check ATM, but I think it's a software limitation you could add a label to your view reference tag family and then manually input the view name...there are free addons that can update parameter to parameter for all instances but unfortunately that's still a manual process. Not sure if that would work in your case but search caseapps.
    December 21, 2010
    C.LONDON
    4,212
    12:37 PM
    Devil's advocate :
    You figure/find out a way. How would you police/manage view name lengths so that they appear in callout heads nicely/uniformly?
    In other words:
    Why would you want to link to a (ever variable, often repeatable) view name, and not "just" (read: purely) the sheet number w/ detail reference?
    Member Duncan's Avatar
    April 28, 2012
    Denmark
    95
    01:37 PM
    Hi Snowyweston
    My reason for wanting this is as follows: I have a project with a lot of elevations (200+) which are collected onto sheets, more than one per sheet, with an index page so one can find which elevation is on which sheet. It is therefore much more useful for someone following a reference to know what the elevation itself is called so it can be found specifically, rather than simply which sheet it is on.
    Edit: So I want a View Reference Family which I can use to reference/link to the View Name of an Elevation View.
    cganiere likes this.
    December 21, 2010
    Phoenix, AZ
    2,210
    04:37 AM
    It might be a day or two before I can post an example but, if this is for elevations then yes, its doable. I have an elevation tag that does this very thing.
    April 28, 2012
    Denmark
    95
    01:37 PM
    Quote Originally Posted by GMcDowellJr View Post
    That would be great!
    December 21, 2010
    Phoenix, AZ
    2,210
    04:37 AM
    View Reference tag that can display a view's name too not just sheet and number data?-2017-03-16_0928.png
    Not sure where the issue lies. Looks like it's a default parameter... or maybe it's been so long since I did this I forgot what I did!
    Attached Files Attached Files
    December 21, 2010
    C.LONDON
    4,212
    12:37 PM
    My money is on being the "hack" that that got posted here many moons ago.
    December 21, 2010
    Phoenix, AZ
    2,210
    04:37 AM
    oh... well, yeah, in that case, I have no idea what i did anymore! lol
    August 22, 2011
    New Orleans, Louisiana
    41
    06:37 AM
    The family and the screen grab you have posted is of an Elevation Pointer, which always had, and still has the View Name parameter. What the OP is asking about it a View Reference family. That still doesn't have the View Name parameter.
  1. view title on sheet won't show until second view is placed
    By elton williams in forum Architecture and General Revit Questions
    Last Post: November 24th, 2014, 08:21 AM
  2. Revit Plan View/Sheet view Symbols
    By JPREng in forum MEP - General
    Last Post: August 27th, 2014, 03:38 PM
  3. Reference other view: <New Drafting View>
    By amarkrish108 in forum Architecture and General Revit Questions
    Last Post: March 18th, 2014, 09:14 AM
  4. turning off layer in sheet view not in plan view
    By birdnehru in forum Architecture and General Revit Questions
    Last Post: October 28th, 2011, 08:58 AM
  5. Display scale on a view title of a 3D view?
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: July 12th, 2011, 08:46 PM
