Results 1 to 3 of 3
Like Tree3Likes
  • 3 Post By PijPiwo
Thread: Staircase Section
    July 1, 2011
    2
    11:55 PM
    Post Staircase Section
    Good people,
    I am trying to create a Cast in Place Monolithic stair in which both stair runs meet the landing at the same point in section. In section the flights meet the landing in what represents a scissor graphic. I hope this makes sense,I have screen shots to explain what I have achieved in AutoCAD and what I get in Revit 2013 when I try to get the same result.
    Staircase plan:
    This is the plan created in AutoCAD.
    AutoCAD Staircase Section:
    Notice the highlighted portion of the flight and landing join.
    Revit Staircase Section:
    Notice the difference with the above section. In this the flight has a slight shift.
    Any help would be appreciated...
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    787
    03:25 PM
    For the lower run, untick ‘end with riser’ and for the upper run tick ‘begin with riser’. Looking at the pictures, I think you have that set already. Next, play with the landing ‘monolithic thickness’ and stair ‘structural depth’. Tab to get to the different parts of the stair. Your values could be different than mine though, depending on the stair construction.
    d.stairmand, vivek and WillyWonka like this.
    July 1, 2011
    2
    11:55 PM
    Thanks for this. It's good to know that it's done through a bit of trial and error!
  1. big staircase issue
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: July 18th, 2014, 03:49 PM
  2. Skirting Along Staircase
    By viratmanchanda in forum Architecture and General Revit Questions
    Last Post: March 10th, 2014, 01:45 PM
  3. Steel Staircase
    By Sushobhan in forum Structure - General Questions
    Last Post: January 16th, 2013, 11:29 PM
  4. Staircase & Railing
    By theshell07 in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2011, 09:28 AM
  5. Staircase
    By Kcooke in forum Architecture and General Revit Questions
    Last Post: December 15th, 2010, 10:25 AM
Tags for this Thread
