Donate Now Goal amount for this year: 3000 USD, Received: 2340 USD (78%)
Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 57
Like Tree19Likes
Thread: Where are A360 Collaboration for Revit local files stored?
  1. #41
    Autodesk
    (Product Line Manager, BDS)
    Kyle's Avatar
    April 3, 2012
    241
    05:43 AM
    Quote Originally Posted by Markus View Post
    I would not recommend it because C4R does not store the locals as a "RVT" file. Instead, they are stored through an obscure GUID schema. If you open the basicinfo.####.dat in Notepad, you may be able to decipher which file it belongs to.
    Files are hidden in the user's appdata local folders: C:\Users\%UserName%\AppData\Local\Autodesk\Revit\. ..\collaborationcache.
    I would let the C4R service to handle this, instead of hacking it. At worse, you may corrupt the model.
    As a side note, Autodesk recommends that you have at least 20+ gb of free disk space for these cache folders.
    Yes, we wouldn't recommend monkeying around with the collaboration cache at this time. As for size allocation, you want roughly 3X the total RVT files that are being actively worked on (links included) + 2GB for the Revit Accelerator cache.
    -Kyle
  2. #42
    August 24, 2016
    6
    03:43 AM
    Kyle,
    Can you delete all files of the collaborationcache folder?
    thanks
  3. #43
    Autodesk
    Kyle's Avatar
    April 3, 2012
    241
    05:43 AM
    Quote Originally Posted by MEPTrevitGuy View Post
    Kyle,
    thanks
    If you want to force Revit to re-download any subsequent cloud workshared models, sure.
    -Kyle
  4. #44
    August 24, 2016
    6
    03:43 AM
    Kyle, we want to delete the huge files that are being saved to local hard drives from the C4R. Can we delete these locals models? Will it cause any problems for the cloud models if we delete these models? thanks
  5. #45
    Autodesk
    Kyle's Avatar
    April 3, 2012
    241
    05:43 AM
    Those "huge files" are cached RVTs that were created for a reason: 1) the team member needed to either directly work on them. 2) they were linked models to a model that a team member was directly working on. Deleting them will cause Revit to download the binary chunks + put Humpty Dumpty back together again the next time Revit needs them -> a vastly longer operation than the normal process of downloading the delta binaries (if Revit Accelerator hasn't already pre-fetched them) & "freshening" the existing local cache. Having a cached RVT = a "hot cache", not having locally cached RVT = a "cold cache".
    With this baseline understanding, it is a really bad idea to actively impose a "cold cache" scenario on any Revit models actively being worked on. That just makes the team member wait much, much longer for the cloud workshared models to load. If space is really a concern, I'd advise that you do an .RVT search into the collaboration cache -> sort by modified date -> delete the really old ones.
    If you're finding that team member don't have sufficient hard drive space for the working copies of the RVTs (we have 3 copies there as part of our local cache architecture, which is designed with the idea that hard drive cost <<< labor cost of team member), I'd recommend you upgrade the drive size.
    -Kyle
  6. #46
    August 24, 2016
    6
    03:43 AM
    Kyle- thanks for the input.
    We also have several projects on the cloud, is there any collation between the cloud models and local models?
    thank you
  7. #47
    Autodesk
    Kyle's Avatar
    April 3, 2012
    241
    05:43 AM
    thank you
    Not sure what you mean by "collation between the cloud models and local models" in this context, so I can't really provide an answer. If you want to clarify a bit, I'm glad to try and provide one.
    -Kyle
  8. #48
    August 24, 2016
    6
    03:43 AM
    thank you
  9. #49
    Autodesk
    Kyle's Avatar
    April 3, 2012
    241
    05:43 AM
    thank you
    I'd advise against re-writing the same previous message, but rather explaining what you mean by your question.
    -Kyle
  10. #50
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,215
    02:43 AM
    Quote Originally Posted by Kyle View Post
    -Kyle
    Kyle, the forum is having a problem with unwanted duplicate posts. Not his/her fault
  1. BIM & Beam: A360 Collaboration for Revit
    By BIM & Beam in forum Blog Feeds
    Last Post: January 15th, 2015, 03:15 PM
  2. Replies: 0
    Last Post: December 3rd, 2014, 09:45 AM
  3. Revit OpEd: Username and Local Files
    Last Post: November 21st, 2014, 04:15 AM
  4. local help files to pdf
    By biff in forum Architecture and General Revit Questions
    Last Post: December 1st, 2012, 08:30 AM
  5. Recovery Files - Local or Central?
    By snowyweston in forum Worksharing, Revit Server & C4R
    Last Post: November 18th, 2011, 10:17 PM
