Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree8Likes
Thread: My Revit Template.....
  1. #11
    Member kowen1208's Avatar
    January 18, 2013
    Utah
    354
    10:10 PM
    Quote Originally Posted by ryntau View Post
    Couldn't you override Object Styles until you need to print then switch them back to black? It's a bit of a hack, but the request is a bit unorthodox for Revit.
    So long as you print with Black Lines selected (Print>Setup>Colors), there shouldn't be any problems with leaving them color. Now, some firms may use Color or Grayscale to have specific lines print grayscale, in which case all lines would print grayscale.
    One solution could be to have the view templates for printed views that use only black lines, and view templates for working views that use color.
    Lkenshalo likes this.
  2. #12
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,186
    12:10 AM
    Quote Originally Posted by kowen1208 View Post
    That is what I would do. I use color filters / overrides all the time when I'm working to visually figure out what I'm dealing with but my VT for views that end up on sheets are all B/W
  3. #13
    Rotterdam, South Holland
    3,059
    06:10 AM
    indeed, different view types, view templates and filters for WORKING views, COORDINATION views, MANAGEMENT views, etc. Lots of views is a good thing, when those views provide meaningful, useful information.
  4. #14
    Senior Member
    June 14, 2011
    CT, USA
    582
    12:10 AM
    I think the point here is to get away from colors being representative of how stuff will plot on a non-color plotter. We are using colors to differentiate systems and plan on continuing with that practice. Although our annotative linestyles are presently colored, they will be changed to black/white before the content is put into our library.
  1. Building a Revit Template
    By Twiceroadsfool in forum Tutorials, Tips & Tricks
    Last Post: January 31st, 2019, 07:31 PM
  2. Revit Structure template
    By phanquynhtrang in forum Structure - General Questions
    Last Post: April 16th, 2014, 04:47 AM
  3. Schematic template vs. general purpose template + workflow (long winded post, sorry)
    By kpcarch in forum Architecture and General Revit Questions
    Last Post: September 10th, 2013, 07:27 AM
  4. Documenting the Revit Template
    By kpcarch in forum Tutorials, Tips & Tricks
    Last Post: August 16th, 2012, 10:42 PM
  5. how i can reset revit template ?
    Last Post: September 28th, 2011, 02:28 PM
Tags for this Thread
