Results 1 to 5 of 5
Like Tree3Likes
  • 2 Post By PijPiwo
  • 1 Post By smith125
Thread: Arch wall Connection with structural column
    November 8, 2014
    12
    11:48 AM
    i have a arch wall connected with column but it doesn't cut as it will be built.please see attachment, so when i calculate quantities it takes the all wall instead of stooping at the edge of column. so what is the possible solution for that. Thanks
    Attached Thumbnails Attached Thumbnails Arch wall Connection with structural column-wall-connection-column.jpg
    November 14, 2014
    Maryville, TN
    17
    04:48 AM
    Is the column copy/monitored into your file? If so you should be able to use the cut tool to cut the wall.
    November 8, 2014
    12
    11:48 AM
    Quote Originally Posted by swdebenport View Post
    I have not yet received structural design so i placed column approximately, coming to your point i tried to experiment with copy monitor but didn't secede as the materials are different of wall & column so it didn't cut, or may be i am not doing properly. can you guide me a bit further. Thanks
    Senior Member PijPiwo's Avatar
    May 20, 2011
    Chicago, IL
    787
    03:48 AM
    Is this a timber column? In the column family, create a void extrusion (initially a solid, then turn it into a void) same size as column, tie/lock its geometry to column’s W, D & H parameters, tick ‘cut with voids when loaded’ in properties and use cut geometry tool in the project to cut the wall.
    smith125 and Ning Zhou like this.
    November 8, 2014
    12
    11:48 AM
    Quote Originally Posted by PijPiwo View Post
    Works like a champ! Thanks
    swdebenport likes this.
  1. Structural Concrete Column Doesn't cut CMU Wall?
    By TRWhitehead in forum Structure - General Questions
    Last Post: April 25th, 2015, 12:16 AM
  2. Concrete beam to column connection
    By ahmed_nox in forum Structure - General Questions
    Last Post: September 15th, 2014, 06:09 AM
  3. Column to Beam Connection
    By gdoherty0102 in forum Structure - General Questions
    Last Post: October 24th, 2012, 12:08 PM
  4. connection (irregular column family)
    By r7_human8y in forum Architecture and General Revit Questions
    Last Post: December 17th, 2011, 04:40 PM
  5. beam-column connection
    Last Post: November 16th, 2011, 09:18 AM
