Results 1 to 3 of 3
Thread: Sheet Specification
    May 22, 2014
    58
    03:59 AM
    Sheet Specification
    How do you set up your sheet specifications in Revit?
    December 21, 2010
    Phoenix, AZ
    2,628
    02:59 AM
    Text in Revit blows. I'd avoid this route if at all possible.
    If not you can copy-paste from your spec into a text field in Revit and deal with constant formating issues (formating changes depending on zoom factor).
    It's been a loooong time but I think you can link in text into AutoCAD from outside sources so, if that's correct, you could, I suppose, link the text to AutoCAD and then link the DWG into Revit (link, not import). Change the text, refresh in AutoCAD, and reload in Revit.
    Member renogreen's Avatar
    April 27, 2011
    Reno, Nv. USA
    335
    02:59 AM
    If I was going to have sheet specifications I might think about saving them as images and bringing them in Revit that way.
  1. Sheet Scale in Sheet List
    By irneb in forum Architecture and General Revit Questions
    Last Post: November 19th, 2013, 06:42 AM
  2. Level of Development Specification
    By Cyus in forum Architecture and General Revit Questions
    Last Post: November 12th, 2013, 01:42 PM
  3. Writing a specification in Revit
    Last Post: September 17th, 2013, 01:19 PM
  4. What Revit Wants: LOD Specification - 2013 version
    By luke.johnson in forum Blog Feeds
    Last Post: August 23rd, 2013, 12:15 AM
  5. Sheet just became a Detail View, but still listed in Sheet List
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: February 25th, 2011, 09:25 PM
