Results 1 to 4 of 4
Thread: Image to detail component
    Member bangobeat's Avatar
    April 14, 2011
    263
    06:36 AM
    What is the best way to extract image and put it into detail component? Im my case i got PDF format technical drawings. Should i export as a .jpg and put into detail component with right scale?
    How would you handle in my case?
    Btw today is friday ! cheer up guys, soon cold beer and friends incoming!
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    12:36 AM
    Is this in order to create the detail component from the sketch?
    If so, you can use insert>image and pick your image from there. It can be in jpg, tiff, bmp or png I believe.
    April 14, 2011
    263
    06:36 AM
    yeah but whats the best way? i guess PNG format is best for details? and maybe there is some tricks to convert image file and somehow explode to lines..
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    12:36 AM
    I think you can if you take it into adobe illustrator and use the live trace command (but not totally sure) and then once converted to vectors, the file can then be exported to dwg format. but it might just be easier to trace. hth
  1. Detail component family, only 2 types of lines available?
    By bangobeat in forum Architecture and General Revit Questions
    Last Post: May 25th, 2011, 10:37 AM
  2. Detail Component issues
    By Alex Cunningham in forum Architecture - Family Creation
    Last Post: March 16th, 2011, 02:57 PM
  3. Detail Component
    Last Post: December 14th, 2010, 10:42 PM
  4. Detail Component
    By gdoherty0102 in forum Tutorials, Tips & Tricks
  5. Component image in pull down
    By jhendershot in forum Architecture - Family Creation
    Last Post: December 14th, 2010, 08:26 PM
