Results 1 to 7 of 7
Thread: half round roof
    June 15, 2011
    13
    12:41 AM
    half round roof
    Hi All,
    Brand new here, brand new to Revit.
    I'm trying to create an awning over a door opening - I built a fabric wall with an 8" ht. and am trying to place a 1/2 round shaped roof onto it - is this a correct approach? If so, how does one create a 1/2 cylinder shaped roof?
    many thanks, Will
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    11:41 PM
    I'd use the roof by extrusion tool.
    Go to an elevation view where you are looking at the profile of the roof. Then, use the roof by extrusion method, draw the barrel vault profile. It will extrude the roof along that profile.
    Then, you can attach the top of the "wall" to the roof and it will take that shape at the top.
    June 15, 2011
    13
    12:41 AM
    Thanks, dzatto
    I successfully created an extruded roof, but need to fill in the front of it (in elevation view) with, I guess, a 'wall' having a 1/2 round top to it. Is this possible, or should I create a 'component"?
    thanks, Will
    Member renogreen's Avatar
    April 27, 2011
    Reno, Nv. USA
    335
    09:41 PM
    I would create an in-place family - roof, using the revolve tool to create the half round shape.
    June 3, 2011
    PA, USA
    120
    12:41 AM
    Quote Originally Posted by Will P. View Post
    Thanks, dzatto
    thanks, Will
    Just draw a wall and attach it to your extruded roof
    June 15, 2011
    13
    12:41 AM
    Quote Originally Posted by DoTheBIM View Post
    Yup - there it is. thanks!
    dzatto's Avatar
    December 9, 2010
    5,234
    11:41 PM
    Dude, that's what I said in the first place!!
    Glad you got it to work. Revit Rocks!
  1. Roof cut
    By bayswater in forum Architecture and General Revit Questions
    Last Post: June 15th, 2011, 06:07 PM
  2. Contour Lines (half)hidden by topography surface?
    By Munkholm in forum Architecture and General Revit Questions
    Last Post: May 31st, 2011, 06:33 AM
  3. How to Roof Merge/Join to Lower Roof!!
    By crhdesign in forum Architecture and General Revit Questions
    Last Post: April 30th, 2011, 05:48 AM
  4. Roof with different sloping - one roof or individual surfaces?
    By Clogboy in forum Architecture and General Revit Questions
    Last Post: April 9th, 2011, 12:47 PM
  5. Half block reveal with full block above
    Last Post: February 22nd, 2011, 03:28 PM
