Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By rosskirby
Thread: Detail Items not showing in callouts?
    August 8, 2014
    3
    07:22 PM
    Hey, really hope I'm not being stupid here.
    I can't get detail items to show up in callout views. That's literally any family that appears under the 'Detail Items' heading, which is kind of annoying because the whole point of the callout is to do a detail. They will place, but revit always comes up with a warning box that says 'Element not visible in plan view' - similar to when an offset makes something like a column or ceiling invisible in a certain view. Detail items have been used in drafting views with no issues, but this detail kind of has to be based on the plan. Things I've tried, with no success:
    • Detail level (set to fine)
    • Visibility graphics (everything is selected and should be showing)
    • Creating a plan region with no offset from the plan (no joy)
    • Creating a detail callout rather than the normal plan view callout (same)
    Detail lines, filled regions, insulation etc all show up with no problems, but there's quite a lot of this drawing that I have neither the time nor patience to draw out with a million detail lines (steel shutter roller guide sections etc). Can anyone help?
    Thanks a lot...
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    02:22 PM
    can you post a cleaned up version of your file?
    also this: http://www.revitforum.org/tutorials-....html#post3719
    August 8, 2014
    3
    07:22 PM
    Thanks for the reply.
    Sorry, but no, it would take more time to clean it up (VERY big file) than it's probably worth.
    Pretty sure it's none of the 33, I'm aware of that list, but thanks for the thought. In the end, I managed to find a separate CAD version of the area in question which I could insert into a drafting view and then work over. So that's a solution of sorts, I suppose.
    Still no idea why they weren't showing up, but it's no longer urgent...
    Member rosskirby's Avatar
    December 16, 2010
    Marietta, GA
    139
    12:22 PM
    You're sure it's not a filter? You can have an element category turned on in visibility graphics, and you'll still get the "Element not visible..." error if there's a filter that (for whatever reason) is turning off detail components in that view.
    Alchemistic likes this.
    December 4, 2012
    Sweden
    66
    07:22 PM
    Have you tried turning of crop region? perhaps they're being placed outside of it.
    December 8, 2016
    2
    01:22 PM
    @RossKirby - I was having same issue and it was a filter. Good call.
  1. Room Tags not showing up in Callouts
    By Lox in forum Architecture and General Revit Questions
    Last Post: July 9th, 2015, 09:01 PM
  2. Can I show selected demolished items without showing all demolished items?
    By lost again again in forum Architecture and General Revit Questions
    Last Post: March 24th, 2013, 08:34 AM
  3. Floor Plan Callouts and Detail Callouts
    By RaiderArch in forum Architecture and General Revit Questions
    Last Post: December 29th, 2011, 04:20 PM
  4. Existing items showing up gray on renderings
    By Wiley in forum Architecture and General Revit Questions
    Last Post: June 15th, 2011, 09:52 PM
  5. Detail Callouts...Sim, Opp, Sim/Opp
    By MikeMaloney in forum Architecture and General Revit Questions
    Last Post: February 19th, 2011, 12:40 AM
