Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Text on two lines:
  1. #11
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    587
    07:28 AM
    one SP, align label top left, drag the label length (right side) to intended return position, insert space ( ) in text string. single string will keep going past the label end. not tested in 2012 btw.
    sim plicity
  2. #12
    February 3, 2011
    London, Ontario
    397
    01:28 AM
    Quote Originally Posted by ekkonap View Post
    sim plicity
    Can you elaborate on this a little bit? Are you saying you insert parentheses "( )" characters in your title block family?
  3. #13
    February 3, 2011
    London, Ontario
    397
    01:28 AM
    Thing is with that method though you're breaking the point of parameters somewhat by combining fields into the one, I mean, sure, it works, but would it not be easier to not use the carriage return "trick" and have SP fields for the contractor's address, phone number and such? Personally, I'm fond of exploiting the "Project Information" category in this way - but that might just be me.
    Agreed. The only time this is really a problem for us (it seems) is when we want to force the sheet title to two lines. Otherwise it's SP's all the way...
  4. #14
    February 3, 2011
    London, Ontario
    397
    01:28 AM
    Quote Originally Posted by Gordon Price View Post
    I have two Labels in mine. One is short, one is long, both use the same Parameter. Also both are bottom justified. Visibility is controlled by Type Parameter. So my 1 and 2 module view titles use the short version, and the text will stack up, the rest use the single line at 3 modules wide, as a title longer than that is just silly.
    Gordon
    Hey Gordon,
    Would it be too much to ask for a sample of this somehow?
  5. #15
    February 3, 2011
    London, Ontario
    397
    01:28 AM
    Quote Originally Posted by Dave Jones View Post
    no, it seems like it's not doing anything until you get done and there are carriage returns where you have done a Ctrl-M
    Got this to work! But not in the sheet name parameter...
    Soo close!
  6. #16
    Member feio's Avatar
    December 13, 2010
    Decadent Lisbon
    450
    06:28 AM
    I would just like to add that the sheet name seems to be the exception for those CRTL+M cases.
  7. #17
    February 3, 2011
    London, Ontario
    397
    01:28 AM
    Quote Originally Posted by feio View Post
    Correct you are feio - sheet name is defiantly the exception.
  8. #18
    May 23, 2011
    Netherlands
    587
    07:28 AM
    Quote Originally Posted by Jj Mac View Post
    sorry. exceptions aside, in a label as in any text block, the spaces between words define the place where a text string in a label returns to the next line, as soon as the text string passes the end of the label box thingy. as for line spacing distance, no options but a separate label, alas.
  1. Revit and Text
    By Alex Cunningham in forum Tutorials, Tips & Tricks
    Last Post: June 3rd, 2015, 07:10 AM
  2. text in schedules
    By redmonki in forum Architecture and General Revit Questions
    Last Post: May 26th, 2011, 07:15 AM
  3. Text Leaders
    By Patrick in forum Architecture and General Revit Questions
    Last Post: April 25th, 2011, 09:13 PM
  4. text background
    By jbenoit44 in forum Architecture and General Revit Questions
    Last Post: March 13th, 2011, 09:41 PM
