Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Roof surface pattern, where i can change line weight?
  1. #11
    June 3, 2011
    PA, USA
    120
    01:13 AM
    I don't follow since mine don't follow. See attached. All Roof category object styles set to 12.
    Attached Thumbnails Attached Thumbnails Roof surface pattern, where i can change line weight?-capture.png
  2. #12
    Member Ben-May's Avatar
    December 8, 2010
    Melbourne,Oz
    305
    04:13 PM
    You must be applying that surface pattern by material, the OP was asking how to change the thickness when overiding an elements surface pattern
  1. How is Generic Model Pattern Based different from Curtain Panel Pattern Based
    By shtirlits in forum Architecture - Family Creation
    Last Post: October 5th, 2012, 12:14 AM
  2. Surface Pattern for Topography
    By JCM in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2012, 03:10 AM
  3. Family Surface Pattern Thickness
    By W.Neuok in forum MEP - General
    Last Post: June 1st, 2011, 08:02 PM
  4. Drafting Cut Pattern Line Weights on Walls
    By dzatto in forum Tutorials, Tips & Tricks
    Last Post: May 2nd, 2011, 08:42 PM
  5. Change of Pace
    By Dive_Syko in forum Out There
    Last Post: February 2nd, 2011, 08:40 PM
