Results 1 to 5 of 5
Thread: is it possible to export from revit to 3ds format ?? how?
    Senior Member ahmed_hassan's Avatar
    April 25, 2011
    Egypt
    752
    05:01 AM
    Hello there
    By the way ,i am new user just trying the version and compare it with features on archicad
    February 3, 2011
    London, Ontario
    397
    01:01 AM
    You should be able to export to FBX format, which Max will accept. The few times we have done it, it seems to work pretty well. You just need to prepare a 3D view in Revit, clean it up to show what you need, and then export. You can access the export function from the application menu. Good luck!
    April 25, 2011
    Egypt
    752
    05:01 AM
    Thanks , but i would prefer this way so i can import the 3ds from any programme like sketchup can i import it from skecthup because some time i like to use it ?
    JCM
    JCM is offline
    December 17, 2010
    Pembroke Pines, FL
    571
    01:01 AM
    Well an actual .max format is not available, but if you get it into max via fbx, you can always export it from there as a file sketchup will work with.
    Orlando, FL, USA
    3,141
    01:01 AM
    Another road you can take to go from Revit to 3dMax is via .dwg. In Revit, from a 3d view, do: Export > CAD formats > dwg. > Current view > In export options, select Solid > Acis solids. > save as .dwg. In 3dMax, do: Import > dwg, select your file, and voila, your Revit model is ready for "lights, camera, action" in 3dMax.
  1. Revit Export Layers setup
    By Karalon10 in forum Structure - General Questions
    Last Post: March 28th, 2013, 11:28 AM
  2. Paragraph Format (Bullets) Tool
    By mark b in forum Architecture and General Revit Questions
    Last Post: January 23rd, 2013, 09:16 PM
  3. Replies: 0
    Last Post: May 16th, 2011, 06:25 PM
  4. Revit to 3ds max
    By JCM in forum Rendering and Gallery
    Last Post: March 28th, 2011, 11:45 PM
  5. Family With Multiple Parameters ( excel style format)
    By JCM in forum Architecture - Family Creation
    Last Post: December 28th, 2010, 03:51 PM
