Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By josephpeel
Thread: Do not count 'not placed' rooms
    July 7, 2011
    Rotterdam, Holland
    1,194
    09:08 PM
    What I'm trying to do is create a schedule that tells me the amount of rooms that is required and the amount of rooms that is actually in the model.
    I have also created most of the rooms types that are needed in the model already so that people can choose the one they need from the pull down menu. This all works great and I'm pretty happy with that, there is however one little thing that is weird.
    If I have a room that is not placed in the project, I get a 'not placed' in my room schedule, as it should. BUT when I ask the schedule how many of the different rooms are in the model it tells me 1 for the not placed ones, which of course should be 0. Once I place a not placed room the count stays at 1.
    I want the schedule to say,
    needed: 2, count: 0
    needed: 1, count: 1
    etc.
    Working in 2014, but 2015 does the same thing
    Any idea how to do that?
    May 3, 2012
    1,401
    09:08 PM
    You can filter out the not placed by Level is "at or above" your lowest existing level. Revit sees "not placed" as a lower value than the lowest actual height.
    You can also use Area to filter not placed spaces, but then redundant rooms also report no area.
    DaveP likes this.
    July 7, 2011
    Rotterdam, Holland
    1,194
    09:08 PM
    Problem is when I filter out the not placed rooms they will not be in the schedule at all. I want them in the schedule with a value of 0 for count and a value of x for the number of them needed (manual parameter).
  1. Color Fill - Only Fills a few rooms not all: how I can fix to color all rooms?
    By revit_user in forum Architecture and General Revit Questions
    Last Post: November 30th, 2016, 07:01 PM
  2. Rooms inside rooms... best practice?
    By Jaime in forum Architecture and General Revit Questions
    Last Post: July 31st, 2014, 12:36 PM
  3. Replies: 0
    Last Post: April 18th, 2012, 07:15 AM
  4. assemblies: the right count
    By jbenoit44 in forum Tutorials, Tips & Tricks
    Last Post: November 5th, 2011, 03:02 PM
  5. Post count
    By Defiant1 in forum Out There
    Last Post: September 12th, 2011, 02:06 PM
Tags for this Thread
