Results 1 to 3 of 3
Thread: Existing Ceiling Grid display
    March 11, 2013
    Bay City, Michigan
    6
    03:49 PM
    Question Existing Ceiling Grid display
    I have an existing ceiling grid on the Architectural Workset that is hosting a new lighting fixture on the Electrical Workset. My phase filter is set to show previous and new. the problem is that the lights are showing up behind the gray ceiling grid which is giving me a "double line". The electrical plans are displaying how I'd like them to, with the dark edge of the light masking the ceiling grid. I think this is some type of workset/discipline issue. Any ideas, other than using annotation lines to override the model?
    Coeur d Alene, ID
    4,783
    01:49 PM
    Modify your light so that it doesn't create an opening in the ceiling....as the opening created in an existing ceiling is the cause of the double line.
    March 11, 2013
    Bay City, Michigan
    6
    03:49 PM
    I was hoping to find a graphical way of producing my desired result, but removing the opening cut will probably be the way I go. Thanks for your assistance.
  1. Centering ceiling grid
    By GMBailer in forum Architecture and General Revit Questions
    Last Post: February 7th, 2018, 08:23 PM
  2. Radial ceiling grid
    By DaveP in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2014, 01:47 PM
  3. Object display in existing phase
    Last Post: February 23rd, 2014, 03:40 AM
  4. Replies: 6
    Last Post: July 3rd, 2013, 10:14 PM
  5. Ceiling Grid
    By domsib in forum MEP - General
    Last Post: April 30th, 2013, 04:25 PM
Tags for this Thread
