Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Dave Jones
Thread: Cannot add mullion in curtain wall grid
    Member gpktm's Avatar
    October 22, 2012
    Melbourne, Australia
    144
    05:15 PM
    Question Cannot add mullion in curtain wall grid
    Hi everyone
    I deleted a mullion from the grid, now when I'm trying to add it back in with "Mullion" command, it can't even see the grid, nevertheless, I can select the grid line, move it, add/remove segment, etc. First, I thought I deleted the segment, but that wasn't the problem. The other strange thing is, when I copy -> paste the whole curtain wall into another project, there I can add a mullion back without a problem.
    Attached Thumbnails Attached Thumbnails Cannot add mullion in curtain wall grid-1-missing-mullion.jpg   Cannot add mullion in curtain wall grid-2-selecting-gridline.jpg   Cannot add mullion in curtain wall grid-3-mullion-placement.jpg   Cannot add mullion in curtain wall grid-4-into-new-project.jpg
    December 27, 2014
    14
    10:15 AM
    Quote Originally Posted by gpktm View Post
    Hi everyone
    Hi, Did you solve this?
    July 20, 2011
    850
    11:15 PM
    i encountered the exact same issue, works OK if copied out to another (new) project, anyone has clue what's going on?
    June 21, 2012
    Tours, France
    896
    07:15 AM
    I have Had seen this several times since here we work a lot with Curtain Walls, as the problem seems to be a mystery what I do as workaround is a copy of the entire wall then I delete that wall and finally I Paste the wall from the clipboard, normally that allows you to add mullions and so on, HTH
    July 20, 2011
    850
    11:15 PM
    seems simple cut/paste won't do the trick, needs to copy out and add mullions there then copy back, thanks Andres for the workaround
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,479
    11:15 PM
    when a curtain wall mullion has been removed from a gridline as shown in the OP it has been removed using the Add/Remove Gridline tool after selecting the appropriate gridline. To restore the mullion use Add/Remove Gridline tool again and select the gridline where the mullion is to be replaced. You can only use the mullion tool when a mullion has been unlocked and deleted. If this were the case in the posted screen shots by the OP there would have remained the joint between the right and left curtain panel. After the mullion has been replaced you can use Type properties to change its type if you like.
    Andres Franco likes this.
  1. Curtain Wall Mullion Mitering
    Last Post: April 16th, 2015, 11:40 PM
  2. Curtain wall mullion
    By mona miller in forum Architecture and General Revit Questions
    Last Post: July 15th, 2014, 01:22 PM
  3. Curtain wall problem: horizontal mullion breaks when the grid is less that 27cm from
    By michal.cyruchin in forum Architecture and General Revit Questions
    Last Post: August 2nd, 2013, 12:40 PM
  4. Curtain Wall Mullion Takeoffs
    Last Post: August 6th, 2012, 07:11 PM
  5. Loading Curtain wall mullion profile
    By TomRuwitch in forum Architecture and General Revit Questions
    Last Post: December 16th, 2011, 06:06 PM
Tags for this Thread
