Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Revit Macros
  1. #11
    Moderator Drew's Avatar
    December 9, 2010
    Perth, Western Australia
    689
    01:27 PM
    I havent really played with macro's in Revit. Can you tell me some of the typical tasks you would be using macro's for? Very interested.
  2. #12
    Member joseguia's Avatar
    March 8, 2011
    102
    12:27 AM
    Aretap,
    gnikrow ti tog uoy dalg
    =) or (=
  3. #13
    March 8, 2011
    102
    12:27 AM
    Drew,
    Its Autodesk's way of exposing the API natively inside of REVIT, I wrote an article sometime back and there's lots of good info shared on this very forum, typical tasks include most of the re items you can do inside of the environment itself.
    Autodesk Wiki - Creating Macros with Revit VSTA
    http://wikihelp.autodesk.com/Revit/e...2-Creating3112
    Revit API – Introduction to VSTA as a rapid prototyping tool
    http://blog.rodhowarth.com/2011/02/r...-as-rapid.html
    Here's a list of REVIT VSTA samples that come with the REVIT SDK, out of the box and a blurb also from the wiki:
    First, let's answer the question: “What are macros, and why would you use them?” Macros are programs that are designed to help you save time, by automating repetitive tasks. Each macro performs a series of pre-defined steps to accomplish a particular task. The steps should be repeatable and the actions predictable.
    For example, you might define a macro to add a grid to your project, to rotate a selected object, or to collect information about the square footage of all the rooms in your structure. Other general examples include:
    Locating and extracting Revit content to external files
    Refining geometry or parameters
    Creating many types of elements
    Importing and exporting external file formats
    C# Samples:
    Simple Samples
    • QuickPrint_FloorPlans
    • QuickPrint_Elevations
    • QuickPrint_Section
    • FindAndReplaceText
    • CapitalizeText
    • FindAndReplaceWinType
    • DeleteObject
    • ProjectInfo
    Common Samples
    • CreateBeamsColumnsBraces
    • GridCreation
    • InplaceFamilyAnalyticalModel3D (Revit Structure only)
    • Rooms (Revit Structure)
    • RotateFramingObjects
    • SlabProperties
    • StructuralLayerFunction
    VB.Net Samples
    Simple Samples
    • CapitalizeText
    • DeleteObject
    Common Samples
    • DesignOptionReader
    • MaterialProperties
    • SlabProperties
    • TestWallThickness
  4. #14
    Junior Member Aretap's Avatar
    April 11, 2011
    Nebraska
    27
    12:27 AM
    Quote Originally Posted by joseguia View Post
    Aretap,
    =) or (=
    Hahaha!!! YEP!
  5. #15
    April 11, 2011
    Nebraska
    27
    12:27 AM
    What he said!
  1. Macros
    Last Post: January 5th, 2011, 01:27 PM
