Results 1 to 3 of 3
Like Tree3Likes
  • 3 Post By Alex Cunningham
Thread: Saving Central file locally onto desktop
    May 7, 2014
    62
    12:54 PM
    Two people have done this... We have a 4 central files, each connected to one another by via shared coordinates, and MEP and Structural models linked into each--12 models in all... I know this process of saving one of the local files to a desktop is far from correct, and not a good practice, but I want to understand all of the implications of doing this. Problems? Issues? Implications? Would their changes still be able to sync? the whole idea scares me...
    Revit Maestro Andre Carvalho's Avatar
    December 13, 2010
    Toronto
    47
    12:54 PM
    Sorry I don't get the part where you says you want to save one of the local files to a desktop. Can you be clear on what do you want to achieve, exactly?
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    09:54 AM
    The act of copying the central file (using windows) to ones desktop will create it into a local file. Now if someone directly opens the central file (in Revit) and saved it to the desktop that's a whole different issue. Directly saving a central file from Revit, that central file now becomes a new central file and loses all of its associations to the original central file. NO ONE SHOULD EVER DIRECTLY OPEN THE CENTRAL FILE!
    If I were you I would break out the beatings stick and whack people up side the head till they start opening and saving files correctly. :coo:
  1. File saving problem
    By kjubas in forum Architecture and General Revit Questions
    Last Post: June 20th, 2014, 02:46 PM
  2. Building Coder: Saving a New Central File to Revit Server
    Last Post: December 12th, 2013, 09:45 AM
  3. Question about Saving to the Central File
    By Alexander_J_Hicks in forum Worksharing, Revit Server & C4R
    Last Post: June 6th, 2012, 03:01 PM
  4. Very slow when saving to central.
    By Raigoki in forum Worksharing, Revit Server & C4R
    Last Post: June 5th, 2012, 11:21 PM
  5. Saving Profile Family from RVT File
    By shiner79 in forum Architecture and General Revit Questions
    Last Post: February 28th, 2011, 06:20 PM
