Results 1 to 9 of 9
Like Tree4Likes
  • 2 Post By josephpeel
  • 1 Post By josephpeel
  • 1 Post By troygates
Thread: Detail Number in a View List Schedule
    Member Steven Thedens's Avatar
    May 2, 2012
    Omaha, Ne
    58
    12:07 AM
    OK, why is "Sheet Number" an available parameter to add to a View List Schedule, but "Detail Number" is not?
    Coeur d Alene, ID
    4,088
    11:07 PM
    Hmm....
    Gold Coast
    1,948
    04:07 PM
    Quote Originally Posted by Steven Thedens View Post
    Because detail numbers are derived from the sheet. You are scheduling views. I'm guessing the sheet number view is a special under the hood factory programmed arrangement for view schedules, whereas detail number is not?? There maybe an addin available or the API may be able to do it?
    May 3, 2012
    1,149
    08:07 AM
    Get rid of the detail number from your titles and just use Title on Sheet, which is scheduleable. Put a number in front of the name if needed.
    (Also because the main view is always automatically numbered 1. so your details on the sheet start at 2. and you have to first change the main view number before you can number your details......all an unneccesary waste of time IMHO)
    elton williams and Ning Zhou like this.
    Coeur d Alene, ID
    4,088
    11:07 PM
    I see what Steven is questioning....you can get the "Sheet Name", the "Sheet Number" and the "Title on Sheet"....all Sheet values mind you....but no "Detail Number".
    I'm guessing the Factory left enough bread crumbs to get you to the proper sheet location and then all you need to do is click the proper view in the Project Browser and you can see the Detail Number in the properties when selected...
    May 2, 2012
    Omaha, Ne
    58
    12:07 AM
    MP, that's exactly what I'm referring to.
    A user can always look at the Properties of a given element when that element is selected. So, yes, the information is available. We just want to leverage that information into a Schedule so users can find stuff easier.
    This isn't a Schedule that will be placed on a sheet. It's a tool for the project architect to look at the list of 117 drafting views and see that 23 of them haven't been placed on sheets and easily find the 94 that have been placed.
    May 3, 2012
    1,149
    08:07 AM
    If you want to know what is on a sheet and what isnt you can also use the project browser settings (View->UserInterface->Browser Organisation).
    On projects with a lot of sheets I sort views by discipline and then the first 2 carachters of the sheet number (Which is also the discipline in our case). So everything under a particular discipline sorts into two groups, "XX" discipline number for views on sheets and "??" for views that are not on sheets. Then everyone can see what are 'work' views that can be changed or deleted, and what is already on a sheet and shouldnt be messed with.
    elton williams likes this.
    Member troygates's Avatar
    December 17, 2010
    Southern California
    142
    11:07 PM
    Here is a quick macro that will take the built-in Detail Number for views on a sheet and place it into a parameter called "Detail_Number". You need to create this project parameter (with text for the type of parameter) first before running the macro. Its easiest to just create the parameter while in a view list schedule.
    The macro would need to be ran often if you are adding/removing/changing views on sheets to update the numbers.
    Also, be aware that if you change the values of the new Detail_Number parameter, it won't change the value of the built-in parameter's values. If you are interested in a macro that does this let me know.
    Code:
    public void DetailNumber()
    	UIDocument uidoc = this.ActiveUIDocument;
    	Document doc = uidoc.Document;
    	string strDetailNumber = "Detail_Number";
    	FilteredElementCollector collector = new FilteredElementCollector(doc);
    	ICollection<Element> collection = collector.OfClass(typeof(View)).ToElements();
    	using (Transaction t = new Transaction(doc, "Detail Number"))
    		t.Start();
    		foreach(Element e in collection)
    			View v = e as View;
    			try
    				Parameter bpDetailNumber = v.get_Parameter(BuiltInParameter.VIEWPORT_DETAIL_NUMBER);
    				v.get_Parameter(strDetailNumber).Set(bpDetailNumber.AsString());
    			catch
    		t.Commit();
    Edit: Wrote up a blog post explaining the process at http://revitcoaster.blogspot.com/201...ers-macro.html
    Ning Zhou likes this.
    March 11, 2015
    4
    06:07 AM
    Hi Troy,
    i would be interested in being able to change detail numbers on the fly by schedules. thanks
    Quote Originally Posted by troygates View Post
    Code:
            t.Start();
                View v = e as View;
                try
                catch
            t.Commit();
    Edit: Wrote up a blog post explaining the process at Revit Coaster: View Schedule with Detail Numbers Macro for Revit
  1. Door number/tag, not showing in schedule
    By Segami in forum Architecture and General Revit Questions
    Last Post: February 9th, 2014, 09:27 AM
  2. Hide grid number in detail view
    By pieter3 in forum Architecture and General Revit Questions
    Last Post: November 16th, 2012, 08:54 PM
  3. "Detail Number" in the View List
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: November 14th, 2011, 02:21 PM
  4. Schedule "Referencing Sheet" for my View List
    By kirklyncox in forum Architecture and General Revit Questions
    Last Post: May 23rd, 2011, 08:51 PM
  5. Sheet just became a Detail View, but still listed in Sheet List
    By LeanneZ in forum Architecture and General Revit Questions
    Last Post: February 25th, 2011, 10:25 PM
