Results 1 to 8 of 8
Thread: Revit 2012
    United States
    1,148
    08:34 AM
    Revit 2012
    I am currently working on upgrading our office to 2012 and a few of the template files are giving me the attached error.
    I have checked my graphics card and it is Revit 2012 Recommended and I have installed the recommended driver for it as well.
    Another thing I find odd is that when I go to open a file in Revit, it does not show all of the same files (rvt, rfa, etc) that show if I were to open the same file through Windows Explorer.
    This error, and not being able to open all the files is making it rather difficult to upgrade, anyone have any ideas?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    02:34 PM
    Quote Originally Posted by gdoherty0102 View Post
    As for the error warning: I'm not an expert, but what the experts here would normally tell you: try up-/downgrading your driver. It's a tedious process but will normally do the trick.
    As for the reason you won't see all file types: that's because Revit makes the assumption that by using the Open button, you want to open a project and not a family (rfa) or template file (rte). You are aware that there is a batch upgrade tool are you?
    Administrator Ian.Kidston's Avatar
    Melbourne, Australia
    1,145
    12:34 AM
    Hi Grant
    If you use the Open - Revit File (opens all types of revit files) from the Big R button, do you now see all of the files available?
    United States
    1,148
    08:34 AM
    So I figured this one out and its my stupidity. It is still odd that I got the error, but the reason for the error, not being able to open the files from Windows Explorer, and not seeing those files when trying to open through Revit is because they were all .rft files. I completly forgot that you had to change the rft files to rfa files to open them in Revit.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,016
    09:34 AM
    .... you had to change the rft files to rfa files to open them in Revit.
    Hold on there. If you are change the files extensions of your .rft files, you're not using them correctly.
    You should see the rfts when you go to New...Family. An .rft is intended as a template fro a family. They are basically empty, and would have no use once renamed. If you are renaming the rfts and then editing them to make families, that's a - shall we say - unusual workflow.
    United States
    1,148
    08:34 AM
    I understand that, but to upgrade my 2011 rft to a 2012 I change it to an RFA, upgrade it, save, then change it back to an rft.
    1,145
    12:34 AM
    Whoa...thats an awful lot of work. Did you try the "upgrade.bat" file which does this automatically - without changing any file names?
    Also have a look at http://revitforum.org/showthread.php...m-2011-to-2012 discussion on similar topic
    United States
    1,148
    08:34 AM
    The upgrade.bat file does not work on rft format either, because all the bat file does is open the file, save and close and since you can't open rft files in Revit, it can not do those.
  1. REVIT 2012 problems?
    By wbenatti in forum Architecture and General Revit Questions
    Last Post: June 25th, 2011, 01:08 PM
  2. Opening Revit 2012 projects within Revit 2011
    By jennscollan in forum Architecture and General Revit Questions
    Last Post: May 21st, 2011, 08:24 PM
  3. Revit 2012 - Autodesk 2012
    By jbenoit44 in forum Forum Français
    Last Post: May 11th, 2011, 07:07 PM
  4. Revit 2012 is HERE!
    By shiner79 in forum Architecture and General Revit Questions
    Last Post: April 8th, 2011, 01:08 PM
  5. Revit 2012
    Last Post: March 29th, 2011, 12:01 AM
