Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Updating content from 2011 to 2012
    DD1
    DD1 is offline
    March 30, 2011
    MELBOURNE
    26
    03:22 AM
    I am about to begin the process of upgrading our families / content to 2012.
    There are a couple of ways I seem to be able to do this.
    1.- Use the Content Batch Upgrade Utility Tool from revit
    2.-Use the File upgrader from autodesk labs
    (http://labs.autodesk.com/utilities/adn_plugins/)
    Is one way better than the other, or is there another way I don't know about?
    Thanks.
    Member joseguia's Avatar
    March 8, 2011
    102
    11:22 AM
    This thread should probably be moved .. its more general and less "Structural" related..
    I'm working on something .. will post soon .. I actually cant get the autodesk labs one to load .. can you post a screenshot?
    JTB
    JTB is offline
    Member JTB's Avatar
    December 30, 2010
    Athens, Greece
    124
    06:22 PM
    Quote Originally Posted by joseguia View Post
    Same here... doesn't work for me.
    Kingdom of Denmark
    4,204
    05:22 PM
    Moved to the General forum
    Working fine on my end... screenshot attached
    Attached Thumbnails Attached Thumbnails Updating content from 2011 to 2012-fileupgrader.png
    9,911
    11:22 AM
    I use the standard batch upgrade utility. I have two versions of it, one edited to upgrade RVT's instead of RFA's. This year was somewhat of a rarity (every file was upgraded manually), but the standard ones work fine as long as:
    1. You copy the directory somewhere local (no network).
    2. You run it locally.
    3. You then run the backup deleter.
    4. You then copy it to its new home on the network.
    We cant run it on the network since the .bats are disabled at the IT level, and running it on networks (at least circa 2010 and 2009) caused all of the new families to be named with long timestamps or something.
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    04:22 PM
    Cannot load either...
    Kingdom of Denmark
    4,204
    05:22 PM
    Quote Originally Posted by mdradvies View Post
    Are you guys reading the "readme" file, and unblocking the .zip file?
    "Mark Twain"
    mdradvies's Avatar
    December 16, 2010
    Boxtel, Netherlands
    4,551
    04:22 PM
    Quote Originally Posted by Munkholm View Post
    No, off course not!
    What´s the fun in that?
    Works fine here too...
    December 13, 2010
    Ambleside, Lake District, UK
    924
    04:22 PM
    Many thanks for pointing out the Autodesk Labs add-in.
    Works perfectly for me whereas the old standard batch upgrade utility wouldn't.
    DD1
    DD1 is offline
    March 30, 2011
    MELBOURNE
    26
    03:22 AM
    Thank you all for your comments.
    Does anyone have a preference for one over the other? Or are there advantages of one over the other?
    Cheers
  1. Linked files updating
    By jpdomein in forum Structure - General Questions
    Last Post: May 15th, 2014, 02:41 PM
  2. 2012 Missing Templates Content
    By mark b in forum Architecture and General Revit Questions
    Last Post: March 8th, 2013, 03:53 PM
  3. Custom content vs. manufactures content & File locations
    By Nate L. in forum Architecture and General Revit Questions
    Last Post: May 16th, 2011, 05:55 PM
  4. 2012 vs 2011 Worksharing Monitor
    By DaveP in forum Architecture and General Revit Questions
    Last Post: April 26th, 2011, 09:08 PM
  5. ASHRAE Viewer for Revit MEP 2011/2012
    By troygates in forum MEP - General
    Last Post: March 31st, 2011, 11:08 PM
