Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Updating content from 2011 to 2012
  1. #11
    December 13, 2010
    Ambleside, Lake District, UK
    736
    07:35 PM
    I prefer the add-in simply because it works and is less trouble - although it doesn't seem to work on sub-folders so you have to go through them one by one... but you can't have everything
  2. #12
    8,478
    01:35 PM
    I prefer the batch script. I typically only have to reset it and run it 4 or 5 times to get through the entire library (reset referring to when the journal encounters a problem and defaults to interactive mode).
    Our library is pretty small, since we started it over last year from scratch... But, the batch script did the ENTIRE library (nested folders and all) of 2200 pieces, while i was gone at lunch.
  3. #13
    DD1
    DD1 is offline
    March 30, 2011
    MELBOURNE
    26
    06:35 AM
    I ended up using the batch script. It seemed the easier one to set up and use. It was all done in a couple of hours, and no problems that I have seen (or have noticed yet).
    Thanks for all your input.
  1. Linked files updating
    By jpdomein in forum Structure - General Questions
    Last Post: May 15th, 2014, 02:41 PM
  2. 2012 Missing Templates Content
    By mark b in forum Architecture and General Revit Questions
    Last Post: March 8th, 2013, 03:53 PM
  3. Custom content vs. manufactures content & File locations
    By Nate L. in forum Architecture and General Revit Questions
    Last Post: May 16th, 2011, 05:55 PM
  4. 2012 vs 2011 Worksharing Monitor
    By DaveP in forum Architecture and General Revit Questions
    Last Post: April 26th, 2011, 09:08 PM
  5. ASHRAE Viewer for Revit MEP 2011/2012
    By troygates in forum MEP - General
    Last Post: March 31st, 2011, 11:08 PM
