Results 1 to 7 of 7
Thread: Preventing new elements showing in view
    Member KWilkinson's Avatar
    November 9, 2012
    150
    01:38 AM
    Not sure if there is a simple answer to this or not...
    I have a series of views where I have isolated elements of my model (curtain walling in this instance). When new objects are created, because they weren't part of the original selection set that was isolated they also appear in the view which I don't want.
    My question is, is there any way to prevent this happening or do I need to keep isolating just the elements I want to see in the view?
    Cheers
    K.
    ps I should add that I currently have the elements I want in the view set up as a selection set so it's easy to reset the view, my concern is another user coming in and not realising that might need to be done before issuing.
    February 2, 2011
    Montreal/Paris
    830
    07:38 PM
    Use Filter to make sure any added elements that fits in the selection gets picked up
    November 9, 2012
    150
    01:38 AM
    Presumably though there is no way to automatically apply a filter?
    Rotterdam, South Holland
    3,066
    02:38 AM
    If you apply the filter in a View Template, and assign the View Template to the View Type, it will automatically get applied at view creation. If you later change the View Type, you will need to manually apply the appropriate View Template, but it is a single step, and all the various view settings flow consistently from that.
    Gordon
    Member rosskirby's Avatar
    December 16, 2010
    Marietta, GA
    139
    06:38 PM
    Other than view templates, as others have mentioned, some people (including us) use a "Legends" phase that occurs before the Existing phase. Create 2 phases that occur prior to Existing. Make a model group of your storefront/curtainwall. Place an instance of that group in the earliest phase before Existing. Tab-select that curtainwall and change its Phase Demolished parameter to the 2nd phase that occurs before Existing.
    Now you've got a smart object that is directly related to whatever changes you make in your model, and since it is created and demolished before Existing, it will never show up in your CDs. Just create an elevation of the various curtainwall groups, place it on a sheet, and you're good to go.
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,044
    07:38 PM
    Filters and View Templates, yes, will be applied automatically.
    However, I'm reading that you've got a Selection Set that you want to see exclusively.
    Unfortunately, I don't think there's any way to do that.
    Unless, maybe Harry is listening...
    3,066
    02:38 AM
    Inverse filter is better than selection set. You could have LEGEND in the Comments for all these object, and then a filter that just turns off anything that doesn't say LEGEND. Be aware, that trick does nothing for addressing schedules, which is where phasing, or my preference Design Options, come into play. And if you go either of those routes, then visibility is already covered.
    If, on the other hand, this is content that really is part of the main model, and just needs documented separately, then filter is the way to go.
    Gordon
  1. 3D Family showing in Plan View
    By domsib in forum Architecture and General Revit Questions
    Last Post: July 10th, 2013, 02:31 PM
  2. Elements incorrectly showing as View Worksets
    By Dandharma in forum Architecture and General Revit Questions
    Last Post: February 12th, 2013, 06:26 AM
  3. How to get elements by view
    By YikaiLee in forum Third party Add-Ins, API and R&D
    Last Post: April 26th, 2012, 08:15 PM
  4. Phase Filter Previous+Demo NOT showing my demo elements?
    By sebaldsl in forum Structure - General Questions
    Last Post: April 25th, 2012, 04:30 PM
  5. question of showing texture while view 3d
    Last Post: April 27th, 2011, 09:46 PM
